Broke Exhaust Manifold Bolt Help!!!!!!
Old Jan 15, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
I need some help peops, I recently installed my new dc sports header and I overtorqued the middle bolt connected to the engine block and broke the bolt along with the screw stickin out right off. Im stuck. Anyways I have 2 other bolts and 2 screws holding the SUCKER down but Im concerned about leakage in the future. HELP. How can I replace the engine screw that holds the header to the engine???????PLEASE HELP
Old Jan 15, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
First, remove the header.
Then see if any of the bolt is sticking out of the block. If it is grab with vice grips and remove.
If its flush with the head, you might want to have a mechanic look at it.
Old Jan 16, 2005
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
before trying to remove it, soak it in pb blaster, a lot. whatever you do do not try an ez out. chances are it will just break off and create a bigger problem if you have a little bit of the bolt sticking out, and can fit 2 nuts on it, that would be ideal
cukaracha
Aug 27, 2015 02:02 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Theshwartz35
Jul 17, 2015 11:13 PM
muttleytm
Jul 14, 2015 05:31 PM
hayden55
Jul 8, 2015 11:38 PM
