unhooking or dead battery
For some reason my mind is blank and I cant remeber this. My girlfriends, roommate has a battery the terminals are loose on, I know that if she doesnt get it tightened the battery will go dead cause the alternator cant charge it blah, blah, blah. Alright i know on the old cars w/o ecu all that I know you can crank them and chunk the battery cause the alternator runs the car. Ok so my question is this can you do this on the new cars?
Someone correct me If I'm wrong
But I believe that the battery and the alternator are more interconnected. The main draw on the alt is to charge the battery. I'm not sure of the porportions of draw from the battery compared to the alt of electrical devices in the car. But I believe many components run off the battery.
Turbos, Engines, Chassis and Suspension Tech
The battery is an integral part of the electronics system of a car.
Some cars with very high output alternators can run without a battery, which is why NHRA mandates a battery AND alternator kill switch.
Some cars, such as sprint and top fuel cars, run what is known as a magneto, which makes its own power to run the ignition system, and needs neither alternator or battery.
If the battery is dead to the point of no charge at all, then most likely the car will not run on alternator alone. But if the battery has a partial charge, just not enough to start the car, then it will run.
I dont think its safe to do this anymore with modern cars that have computers in them. On older cars you could disconnect the battery to see if the Altenator is bad, but on newer cars its supposedly bad for the electrical/computer system.
Originally Posted by realitycheck
See thats what I was thinking I thought I heard somewhere that in the new cars you CANT just remove the battery once cranked. Because the car will still go dead. Am I correct??????
Actually, the modern car uses the battery not only for its storage power, but its use as capacitance, meaning it helps to filter out noise and voltage spikes that may damage electronic circuits.
Dave88LX
Electrical
15
May 28, 2020 08:31 PM
DubbleChrisP
Aug 19, 2015 12:37 AM
brady15
Aug 8, 2015 08:16 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
