adjustable fuel regulator
Old Jan 5, 2005
ex_03's Avatar
Godlike member
ex_03 is on a distinguished road
I searched everything in here and could not find so here goes:
I was curious if anyone had installed a B&M or equivelent universal adjustable fuel regulator. I can't seem to find one that is made for my 03 ex coupe, so universal seems the way to go, I put on a run of the mill cold air with no problems, It seems to give a little more hp off the line but, When I floor it it boggs down Im guessing that its becuase Im not matching the added air with more fuel? Thanks fellas..Jeff
Old Jan 5, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Good luck finding one. =)
The new civic/rsx has a returnless fuel system. The pressure is regulated in the fuel tank before the rail.
Old Jan 5, 2005
civic01vtec's Avatar
right, if you install a fpr, you also need to install a intank pump and modify your fuel rail and run fuel line for a return fuel set-up. Also, you would need a piggyback fuel computer to adjust the fuel. This should only be done for boost or n2o.
What you need is a safc........actually, you don't need anything cuz a intake will not make a difference at all. OBD II cars will automatically supply the sufficent amount of fuel needed.
Old Jan 5, 2005
ex_03's Avatar
Godlike member
Thats What I was a afraid of. Well thanks again you guys are always a big help!!.
mrwhos
Aug 11, 2015 02:03 AM
Civicircus
Aug 6, 2015 11:58 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
jzhartman
22
Jul 23, 2015 10:42 PM
