skunk2 coilovers bouncy!!
Old Dec 30, 2004
henzoketchup's Avatar
henzoketchup is an unknown quantity at this point
Question skunk2 coilovers bouncy!!
I Had My Skunks For 1 Year Now And Now Its Hella Bouncy What The F@#$@ Is Goin On? I Slammed My Front And Back Man.. On Lil Bumps Its Like Riding On A Back Of A Horse! And Pot Holes It Fells Like My Tires Blew Out What Sould I Do? Do You Guys Think Its My Oem Shocks Cuz I Havent Changed It Ever Since I Lowerd My Car Please Help ........
Old Dec 30, 2004
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
your oem shocks are more then likely blown. I suggest buying some koni yellows or tokico blues (although im not sure if the tokicos can handle skunk2s slammed. others correct me if im wrong). Both should reduce the bouncy ride. I bet others on this site will say the same
Old Dec 30, 2004
Zzyzx's Avatar
Autocross Junky
^^bingo^^^
Your bouncing problem isnt because of the springs... It's because of the shocks.
Old Dec 30, 2004
What Kinda Shocks Do You Guys Recomend? And How Much A Peice?
Old Dec 30, 2004
jttegx's Avatar
OMNES AD UNUM
whats your budget? do you plan to slam the car with aftermarket shocks still? what are your expectations?
check out the shock/damper faq, it tells ya what aftermarket shocks/struts are out for our cars and whatnot. http://www.7thgencivic.com/forums/sh...d.php?t=171892
Old Dec 30, 2004
exturbo6's Avatar
Well I Had Same Problem With The Bouncing On My 4 Dr Honda. So I Bought Kyb Adjustables, And I Mean It Still Road Like **** So To Say. I Mean It Was Better But For The Money I Spent I Felt It Should Have Been Better..
Old Dec 30, 2004
dirtySAMURAI's Avatar
I log in from time to time
please stop with the caps lock.
koni's should sell for around $550 for the entire set of 4, downside being that you have to cut your stock front struts in order to slide the koni into it.
tokico's i think will be around $300 for the entire set (don't quote me on this), but will not be able to handle the kind of drop you're on (skunk2 all the way down is in the 3" lowered range?). tokico says the max their shocks can handle is 1.75" drop.
Old Dec 30, 2004
Zzyzx's Avatar
Autocross Junky
Oh ya... How low you have the car will also adversly effect ride quality... But if you inetend to drop the car as low as you can... Konis would be your best choice for shocks, as they are designed to have the same valving at any ride height within their stroke range. HOWEVER, if you bottom them out (The shock, not the car) then you will destroy them.
Old Dec 30, 2004
87MugenProCR-X's Avatar
87MugenProCR-X is an unknown quantity at this point
Ive got tokico illuminas on my rex and its dropped about 3 inches with 27.5mm torsion bars and it handles the drop and spring rate good. Harsh ride but not bouncey. But i do agree that the konis would be better
Julian
Old Dec 30, 2004
MY RIDE HIGHT IN THE REAR I MAX IT OUT AND FRONT ABOUT THE SAME HIGHT I DONT KNOW THE MESUREMENTS BUT I CANT FIT ANY FINGER BETWEEN THE TIRES AND THE FENDER. IF I WOULD SLAM IT ALL THE WAY WHAT KINDA SHOCKS SHOULD I GET?
Old Dec 30, 2004
jttegx's Avatar
OMNES AD UNUM
i would say KYB D-spec, koni yellows or KYB AGX imo.
Old Dec 31, 2004
fuzzylogic426's Avatar
fuzzylogic426 is an unknown quantity at this point
the Tokico Blue's and the KYB AGX's will not fit with the Skunk 2 coilovers
i emailed Skunk 2 with this question (and i believe that a member on here told me too). The person working at Skunk 2 told me that the only option is the Koni's
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
TheRiddicles
Sep 21, 2015 01:28 AM
