installing new gauges
Old Dec 12, 2004
rhiggi3ulm's Avatar
rhiggi3ulm is an unknown quantity at this point
i just installed reverse indiglo gauges in my 2002 civic. it came with an on/off switch too. the only problem is that the gauges do not come on automatically when i turn my lights on. i have to turn on my lights, then switch the new gauges on. is there anything to make the gauges come on when i turn my lights on like normal?
Old Dec 13, 2004
shaman's Avatar
shaman can only hope to improve
yes there is..... i am assuming that you did not wire it properly...... there is a thread somewhere that tells you the proper wires to tap... i believe you connect the (+) wire to a green wire, and then the (-) wire you can ground anywhere on your car
Old Dec 13, 2004
Caucasian.Asian's Avatar
^^make sure you look it up before you do it! i don't remember a green wire when i did mine??? but i may be wrong. just look it up.
so does your gauges come one if you have the lights off but you switch the gauges to the on position? if so you probably have them wired to a constant power wich is wrong...
i think you only need to wire to headlights (blue/red wire) and ground
Old Dec 13, 2004
here is a wire diagram that might help right now and for future projects...
http://www.7thgencivic.com/forums/sh...d.php?t=153833
Old Dec 13, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Tap the power wire for the gauge face inverter to the red wire with black stripe, located on the blue (left when facing the dash) plug for the gauges. Ground where you can. Voila.
Old Dec 13, 2004
rhiggi3ulm's Avatar
i'll try the blue/red wire. i have it spliced to the red/black wire on the blue plug. i followed the steps straight out of the DIY. thanks for the feedback
user 84948
Air Conditioning
40
Jul 10, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
AlphaInfinity
Nov 21, 2001 03:15 PM
meels808
Nov 15, 2001 07:16 AM
nickfn
Nov 8, 2001 09:44 AM
