Koni yellows w/ ground control...size?
Old Dec 9, 2004
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
ok what size Koni's do I need for an 01 civic...I searched but nobody really says anything about 01's....another question is, for now I want just the rear shocks, are they just a plug and play type of thing with no modding, like the fronts require...thanks
Old Dec 9, 2004
Zzyzx's Avatar
Autocross Junky
THe 2001's use the 50mm shock (thats what I have). they changed it mid 2002, so some of the 02's ues the 50mm some use the 55mm.,....
the rears are the same for all years.... and Yes they are a direct replacement.
Old Dec 9, 2004
goodtimes's Avatar
how about the 03 model are they going to be 50mm or 55mm
thanks
Old Dec 9, 2004
Zzyzx's Avatar
Autocross Junky
thanks
Mostlikely its the 55mm but its allways best to measure!
Old Dec 9, 2004
djspot's Avatar
fuk tha man!
got another question...I was checking the ground control website...and they I need billet aluminum Koni adapters, which cost on 10 dollars...what are these??? any pics? sorry for the newbie type of question
Old Dec 9, 2004
djmota's Avatar
GET the adapters. They work very well and will keep you from having dropped perch problems. They also make the install cleaner. they fit inside an indentation in the bottom of the rear sleeve.
Old Dec 9, 2004
djspot's Avatar
fuk tha man!
ok kool...I was gonna get them for sure, I just wanted to know what they were...
Old Dec 18, 2004
dbzkid84's Avatar
dbzkid84 is an unknown quantity at this point
Hey you guys what is the measurement for the koni shocks that fit into a 50mm front OEM strut housing?
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
martinsmartin
Aug 15, 2015 07:34 PM
sch2cm
Jul 21, 2015 09:58 PM
newshus
33
Jan 22, 2003 11:32 PM
