Koni yellows w/ ground control...size?
fuk tha man!
ok what size Koni's do I need for an 01 civic...I searched but nobody really says anything about 01's....another question is, for now I want just the rear shocks, are they just a plug and play type of thing with no modding, like the fronts require...thanks
Autocross Junky
THe 2001's use the 50mm shock (thats what I have). they changed it mid 2002, so some of the 02's ues the 50mm some use the 55mm.,....
the rears are the same for all years.... and Yes they are a direct replacement.
Autocross Junky
Originally Posted by goodtimes
how about the 03 model are they going to be 50mm or 55mm
thanks
thanks
fuk tha man!
got another question...I was checking the ground control website...and they I need billet aluminum Koni adapters, which cost on 10 dollars...what are these??? any pics? sorry for the newbie type of question
GET the adapters. They work very well and will keep you from having dropped perch problems. They also make the install cleaner. they fit inside an indentation in the bottom of the rear sleeve.
martinsmartin
Aug 15, 2015 07:34 PM
sch2cm
Jul 21, 2015 09:58 PM
