swapped d17's wont start...
Prowlin' with a Purpose
ok i spun a rod bearing last week.. i got the new motor in everything is connected, everything is in... oil, coolant, gas.. its all full... but it cranks, but wont start... any ideas?
umm im using the one that came in the car i bought.. i have a 01 ex.. the motor came from a 01 ex... it came from an auto, i have a manual.. ecu's shouldnt matter
Wha? Ecu will definately matter if it's auto vs stick!! If you have the big three (air/fuel/spark), then it's a problem with the computer or a sensor.My car almost wouldn't turn over when I had the intake air temp sensor unplugged.
i am using MY 2001 ex 5spd ecu for a d17a2 from a 2001 ex auto... using my 5spd tranny... ECU wont matter
all the sensors are the same...i think the oil/fluids just need to make its way through the motor...
the only thing that has changed about the engine bay is the motor.. the tranny, wire harness, coils, sparkplugs, alternator, starter, ac compressor, ps pump are all from the old motor
EVERYTHING was plug and play.. so to speak, it cranks but doesnt turn over..
its late.. im gonna have my dad check it out in the morning.. he just wanted me to get it to the point where it wont hog his good hoist...
all there is left is to figure out why its not firing... maybe theres a vacuum leak somewhere i forgot to clamp down...
If I were you this is what I would have done:
1.) I would have taken out the crankshaft from the used motor that you bought.
2.) Use the numbers from the used crankshaft and the numbers from on your original block, to determine the rod bearing colors and buy new the rod bearings.
3.) Buy a set of new piston rings. (Might as well change those wile you taking out the crank)
4.) Use your fathers lift and from under the car unbolt the oil pan and then the crank and replace it with the new stuff and there you would have been able to start now.
Anyways, check to make sure you have plugs in the motor. And check your pack connections as well as your injector connections. Go back over every sensor and every plug to make sure you didn't miss one.
As far as the auto motor mating to a manual tranny, it works. I did the same exact thing in mine and had nor problems and it's been over 20k now.
well it turned out i forgot to ground something... and hte battery needed a little kick in the pants...
my dad pulled off one of the hoses and was like, see! theres no fuel in there, then i showed him the old fuel rail and he was like.. wheres the return line?
the engine i put in was a d17a2, same one that was in my car, i purchased the motor from a salvage yard for $700
i got one with 11,000 miles for 300 on ebay........cost me 200 to ship
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
