swapped d17's wont start...
Old Nov 21, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
ok i spun a rod bearing last week.. i got the new motor in everything is connected, everything is in... oil, coolant, gas.. its all full... but it cranks, but wont start... any ideas?
Old Nov 21, 2004
C2i0v0i1C's Avatar
SuperMODrizd
if its the same type engine use the ecu that came with the car, dont swap the ECUs
Old Nov 21, 2004
WannaBFast's Avatar
the engine i put in was a d17a2, same one that was in my car, i purchased the motor from a salvage yard for $700
Old Nov 21, 2004
C2i0v0i1C's Avatar
SuperMODrizd
what bout ECUs
Old Nov 21, 2004
WannaBFast's Avatar
umm im using the one that came in the car i bought.. i have a 01 ex.. the motor came from a 01 ex... it came from an auto, i have a manual.. ecu's shouldnt matter
Old Nov 21, 2004
jturbolx's Avatar
jturbolx is a jewel in the roughjturbolx is a jewel in the roughjturbolx is a jewel in the rough
have spark? injector pulse?? check the crank sensor and cam sensor
Old Nov 21, 2004
Wha? Ecu will definately matter if it's auto vs stick!! If you have the big three (air/fuel/spark), then it's a problem with the computer or a sensor.My car almost wouldn't turn over when I had the intake air temp sensor unplugged.
Old Nov 22, 2004
WannaBFast's Avatar
i am using MY 2001 ex 5spd ecu for a d17a2 from a 2001 ex auto... using my 5spd tranny... ECU wont matter
all the sensors are the same...i think the oil/fluids just need to make its way through the motor...
Old Nov 22, 2004
Oh okay. But what exactly is happening, the car cranks but doesn't turn over?
Old Nov 22, 2004
jturbolx's Avatar
uhmm only gas would have to get to the engine lifters don't have to pump up or anything should start if you have, spark, compression, fuel,
Old Nov 22, 2004
WannaBFast's Avatar
the only thing that has changed about the engine bay is the motor.. the tranny, wire harness, coils, sparkplugs, alternator, starter, ac compressor, ps pump are all from the old motor
EVERYTHING was plug and play.. so to speak, it cranks but doesnt turn over..
Old Nov 22, 2004
Do a compression test to see if all cylinders are at spec psi and similar across each cylinder.
Old Nov 22, 2004
WannaBFast's Avatar
its late.. im gonna have my dad check it out in the morning.. he just wanted me to get it to the point where it wont hog his good hoist...
all there is left is to figure out why its not firing... maybe theres a vacuum leak somewhere i forgot to clamp down...
Old Nov 22, 2004
opto_isolator's Avatar
Fuses? The coil packs rely on 1 fuse, if it blows, it won't start. Check those...
Old Nov 22, 2004
kezay's Avatar
kezay is an unknown quantity at this point
If I were you this is what I would have done:
1.) I would have taken out the crankshaft from the used motor that you bought.
2.) Use the numbers from the used crankshaft and the numbers from on your original block, to determine the rod bearing colors and buy new the rod bearings.
3.) Buy a set of new piston rings. (Might as well change those wile you taking out the crank)
4.) Use your fathers lift and from under the car unbolt the oil pan and then the crank and replace it with the new stuff and there you would have been able to start now.
Old Nov 22, 2004
andyman97's Avatar
Turbo Guru
That'd be a big waste of money and time. A used motor that runs would be easier and cheaper.
Anyways, check to make sure you have plugs in the motor. And check your pack connections as well as your injector connections. Go back over every sensor and every plug to make sure you didn't miss one.
As far as the auto motor mating to a manual tranny, it works. I did the same exact thing in mine and had nor problems and it's been over 20k now.
Old Nov 22, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
Is the battery fully charged? If it sat without recharging it could give you trouble. How is the alternator it could be shot?
Old Nov 22, 2004
WannaBFast's Avatar
well it turned out i forgot to ground something... and hte battery needed a little kick in the pants...
my dad pulled off one of the hoses and was like, see! theres no fuel in there, then i showed him the old fuel rail and he was like.. wheres the return line?
Old Nov 24, 2004
ZapThyCat's Avatar
ZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to beholdZapThyCat is a splendid one to behold
How much did your swap cost...?
Old Nov 24, 2004
HondaLuver's Avatar
Its a celebration bitches!
lol... its always the simple things... like a small plug
Old Nov 24, 2004
WannaBFast's Avatar
well i did all the work myself.. but the motor was about 650
Old Nov 24, 2004
civic01vtec's Avatar
i got one with 11,000 miles for 300 on ebay........cost me 200 to ship
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Scout1
Oct 5, 2015 01:33 PM
juicetayne
Sep 30, 2015 11:02 AM
ThatGuy913
Sep 28, 2015 05:35 PM
ttamrekab
Sep 28, 2015 01:22 AM
