Sponsored by:
Sponsored by: CARiD
header install Q
Old Nov 9, 2004
suthrninca's Avatar
suthrninca is an unknown quantity at this point
header install Q
I'm going to install my kamikaze header this weekend and was wondering if I should go ahead and buy exhaust mani gasket and doughnut before I get started. Never done this before. Is it possible to reuse the old gaskets?
Old Nov 9, 2004
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
You can, but new gaskets don't cost that much.
Old Nov 9, 2004
suthrninca's Avatar
What about header wrap? I now this is not a race car, but it would keep engine compartment temps down. Would it be worth the trouble?
Old Nov 9, 2004
mykungfuisthebe's Avatar
mykungfuisthebe is an unknown quantity at this point
yes get the gasket... dougnut is reusable and yea wrap em.... its easyer to wrap when its off the car.
Old Nov 9, 2004
mr.bojangles's Avatar
mr.bojangles is an unknown quantity at this point
i used my old one with no problem
Old Nov 9, 2004
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
ya i used the old ones too
Old Nov 9, 2004
djmota's Avatar
I have used my old ones a couple of times. No leaks
Old Nov 9, 2004
CapYoda's Avatar
Escaped Convict
general rule of thumbs is to replace them whenever you swap header, whether aftermarket or OEM.
but the general rule of thumb is also suggested cuz you only swap header, exhaust components when there are problems with it.
of course if you've only driven like 1,000 miles and youre swapping your header for an aftermarket one, your stock gaskets are probably fine.
but doesnt hurt to swap it now.. when you unseat those things, funky things happen. in either case you can make the call when you take a look at the gaskets.
wrapping may help, but in our situation.. I think it doesnt do as much as it would... and may damage your header in the long run due to extra stress and heat on the header.
so you should probably just leave the wrap alone.
Old Nov 9, 2004
CapYoda's Avatar
Escaped Convict
also, remember to torque the bolts probably, the stock spring bolt is rather delicate and snaps easily.
do a search on "bolt torque" and or "header torque" and you should find numerous threads with torque spec on the bolts, if you dont know them or have reference to them.
Old Nov 9, 2004
IronFist's Avatar
I used my stock one when I installed the hp top portion header. You can see the link to my DIY in my sig.
Old Nov 10, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
23 ft/lbs on the top bolts, 17 ft/lbs on the bottom bolts..
Old Nov 10, 2004
suthrninca's Avatar
Thanks for the info. I installed it last night. I reused the exhaust mani gasket, but the oem doughnut wouldn't fit on the header down pipe. I took the header and oem doughnut to autozone, they looked for one that would fit without any luck. They let me go through thier stock and I finally found a winner, but I didn't check what car it was made for. Anyway, it's installed with no leaks yet and no cel (got a mil eliminator from bigjosh).
Old Nov 10, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
When I did mine I went ahead and got a 3 inch donut gasket, I trimmed a lil' off the sides of the gasket to make it fit right because it was too small I think. G job on the install
Old Nov 10, 2004
get some pics
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
