wtf my battery died
Old Nov 7, 2004
MegaHurtz's Avatar
wtf my battery died
It's been a couple days since I drove my car and I just went out there to check on it and my battery is dead... what the hell... what could be causing a drain? I have no amp right now so that's not hte problem... any suggestions?
Old Nov 7, 2004
tbaleno's Avatar
tbaleno is an unknown quantity at this point
Door not shut tight, dome light on? lights left on. Trunk open a bit.
Old Nov 7, 2004
LudlamTheory's Avatar
i boogie for the raindrops
well
its one of many things
1 - alarm
2 - stereo
3 - something from the actual car went wrong
4 - the battery wasnt enough to handle your setup
Old Nov 7, 2004
MegaHurtz's Avatar
1... maybe my alarm but how much should it drain when my car is off? I have no LED or anything either..
2... I've thought about it, but what would it be? My deck is on switched power and I have no amp, in fact I've got my breaker turned off right now, so there is no power going to my trunk at all
3... maybe... god I hope not
4.... I upgraded my battery a while ago becuase this happened before and it was fine until now
this sucks, certainly doesn't help my ridiculous stress level
Old Nov 7, 2004
DragonAce's Avatar
DragonAce is an unknown quantity at this point
get yer alty checked when ya get a minute..
doesn't sound like u have anything capable of draining it so only other "possible" option is it's not getting charged correctly
Old Nov 7, 2004
fonto's Avatar
The LA Clipper
What kinda battery is it?
Had you disconected it lately? If so, did you reset your ECU properly?
Old Nov 7, 2004
tbaleno's Avatar
You have to reset the ECU when you unplug the battery?
Old Nov 7, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
If you've messed with any wires under the hood then check the batt to chassi wire and pos and neg terminals to make sure you ahve a good connection. That messed me up and the wire from the batt was loose where it connects to the body.
If it was you alt. i think you would have notice your car running rough before you shut it off. I killed my alt 3 time in my camaro and i could tell every time.
Have you tried to jump it yet?
Old Nov 7, 2004
MegaHurtz's Avatar
haven't jumped it
I don't think it is my alt. the car runs fine, the battery just seems to drain when the car is off
I've d/c my battery a few times before and I've never reset the ECU
I DO have a DVD player that I have on constant (but manually switchable power) that I leave on sometimes, but if its turned off I dont know why it would kill my battery
The battery is an Exide 34XCD
Old Nov 7, 2004
hustlelikem0fo's Avatar
i took my box out of the trunk and the wires going from the amp to the box are just laying in my trunk without being connected to anything. can this drain my battery somehow?
Old Nov 7, 2004
takumi's Avatar
takumi is on a distinguished road
When my battery kept being drained, I just unplugged the power/ground wires and left them there until the Yellow Top came in. It won' get drained since there's no load.
My Honda dealer told me my alarm and system could be slowly draining the battery. They said to avoid this, start the car at least once a day and let it run for at least 5 minutes. I tried that and it didn't work so I just bought a new battery. Maybe it'll work for you, good luck!
Old Nov 7, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
im pretty sure auto zone will check yer electrical for free to see if anything is drawing power..
Old Nov 7, 2004
ohiojosh78's Avatar
No, but if you unhooked your AMP and left the power wire laying around that could drain your battery VERY QUICKLY and probably with some sparks too
Old Nov 7, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Maybe because you've been talking so much **** lately about upgrading your alternator, your current alternator gave you a nice big F-U!
Old Nov 7, 2004
MegaHurtz's Avatar
If my alt is bad will they warranty it considering i put a system in and changed the battery?
Old Nov 7, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Don't know about the warranty. I know that if you leave an alarm set for an extended period of time it will drain the battery. I seriously doubt that's the problem with the short time period. Just check all your interior and exterior lights, other electrical switched devices first to make sure nothing was left on before getting your worry on...
Old Nov 7, 2004
MegaHurtz's Avatar
i've gotta try and remember to keep my video system switched off
Old Nov 7, 2004
dont alarms run on like half a volt or something? i know they take very minimal power to run...... i would assume it would take a hell of a long time for an alarm to discharge a battery? correct me if i'm wrong please cuz i'm under this assumption right now and i dont know too much about alarms haha
Old Nov 7, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
Originally Posted by MegaHurtz
haven't jumped it
as far as i know, the ECU will reset itself anytime you disconnect your battery....
btw, if your battery always gets drained overnight, i would think there's something wrong.
i once left the dome lights on all day and night (and my car has the dual dome lights) but the car still started up perfectly fine.
Old Nov 7, 2004
MegaHurtz's Avatar
it wasnt just overnight, it has been sitting for like 2 days, still very quick I know, hence the fact that I made this thread
Old Nov 8, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
I travel quite a bit for work at times. There was quite a few times that I'd leave the car for a month+ and never had any issues when I got back. It started a little harder than normal but it still started. This was even in the Jan. & Feb. timeframe in NY where it gets damn cold in the winter.
I have 3 neons, HU, Kicker 150.2 amp, and a Kicker 400.1 amp.
Old Nov 8, 2004
MegaHurtz's Avatar
yeah i know i def have a drain, but trying to find it is the question
Old Nov 8, 2004
MegaHurtz's Avatar
well my voltmeter read 12.4v after I shut my car off at school today, hopefully it doesnt go back down again
Old Nov 8, 2004
duyaknow's Avatar
duyaknow is an unknown quantity at this point
ROFL. Why the hell was I thinking the same thing?
Old Nov 8, 2004
12.4 means your battery is bad. turn your car on, leave your system off, and all accessories off for like a good half hour, then after a fewminutes get a reading. should be 12.61 to 12.66 for the battery to be proper. a car lead acid battery has 6 "cells" (the combination of the lead plates submerged in the acid etc etc etc) all wired in series. each one reads between 2.1 and 2.11 volts... when one or more of the cells start reading lower than that, you know the battery is toast.
i'd think an exide has a warranty
now, your thing to do here is get an ammeter and start checking wires coming off the battery for current when the car is off.
Old Nov 8, 2004
againifall's Avatar
Go Team Venture!
my moms accord has an alarm.. it sat for 3 months and started right up.. so dont worry about it being the alarm unless you somehow screwed it up
Uan
Aug 23, 2015 03:03 AM
jnissen
Aug 9, 2015 05:34 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
