wtf my battery died
wtf my battery died
It's been a couple days since I drove my car and I just went out there to check on it and my battery is dead... what the hell... what could be causing a drain? I have no amp right now so that's not hte problem... any suggestions?
1... maybe my alarm but how much should it drain when my car is off? I have no LED or anything either..
2... I've thought about it, but what would it be? My deck is on switched power and I have no amp, in fact I've got my breaker turned off right now, so there is no power going to my trunk at all
3... maybe... god I hope not
4.... I upgraded my battery a while ago becuase this happened before and it was fine until now
this sucks, certainly doesn't help my ridiculous stress level
If you've messed with any wires under the hood then check the batt to chassi wire and pos and neg terminals to make sure you ahve a good connection. That messed me up and the wire from the batt was loose where it connects to the body.
If it was you alt. i think you would have notice your car running rough before you shut it off. I killed my alt 3 time in my camaro and i could tell every time.
Have you tried to jump it yet?
haven't jumped it
I don't think it is my alt. the car runs fine, the battery just seems to drain when the car is off
I've d/c my battery a few times before and I've never reset the ECU
I DO have a DVD player that I have on constant (but manually switchable power) that I leave on sometimes, but if its turned off I dont know why it would kill my battery
The battery is an Exide 34XCD
Originally Posted by HustleLikeM0FO
i took my box out of the trunk and the wires going from the amp to the box are just laying in my trunk without being connected to anything. can this drain my battery somehow?
My Honda dealer told me my alarm and system could be slowly draining the battery. They said to avoid this, start the car at least once a day and let it run for at least 5 minutes. I tried that and it didn't work so I just bought a new battery. Maybe it'll work for you, good luck!
Electric Boogaloo...
Don't know about the warranty. I know that if you leave an alarm set for an extended period of time it will drain the battery. I seriously doubt that's the problem with the short time period. Just check all your interior and exterior lights, other electrical switched devices first to make sure nothing was left on before getting your worry on...
Originally Posted by MegaHurtz
haven't jumped it
btw, if your battery always gets drained overnight, i would think there's something wrong.
i once left the dome lights on all day and night (and my car has the dual dome lights) but the car still started up perfectly fine.
it wasnt just overnight, it has been sitting for like 2 days, still very quick I know, hence the fact that I made this thread
I travel quite a bit for work at times. There was quite a few times that I'd leave the car for a month+ and never had any issues when I got back. It started a little harder than normal but it still started. This was even in the Jan. & Feb. timeframe in NY where it gets damn cold in the winter.
I have 3 neons, HU, Kicker 150.2 amp, and a Kicker 400.1 amp.
Originally Posted by J187
Maybe because you've been talking so much **** lately about upgrading your alternator, your current alternator gave you a nice big F-U!
i boogie for the raindrops
well my voltmeter read 12.4v after I shut my car off at school today, hopefully it doesnt go back down again
i'd think an exide has a warranty
now, your thing to do here is get an ammeter and start checking wires coming off the battery for current when the car is off.
my moms accord has an alarm.. it sat for 3 months and started right up.. so dont worry about it being the alarm unless you somehow screwed it up
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
