Places for 0 gauge grommet in firewall
Old Nov 7, 2004
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
Question Places for 0 gauge grommet in firewall
So in a couple weeks, I will be running 1/0 gauge power and ground to replace my 6 gauge. I've come to the conclusion that 2 0 gauge wires will not fit through the grommet on the passenger side, so I bought 2 1/0 grommets to go through the firewall somewhere else. I was wondering where a good place would be to do that. Anyone that has done this, suggestions would help.
Old Nov 7, 2004
alex053's Avatar
anywhere you drill on the passenger side
Old Nov 7, 2004
MegaHurtz's Avatar
yeah, determine the path of the wires on the engine side of the firewall and drill somewehre close to the existing grommet but OUT OF THE WAY of the existing wires
Old Nov 7, 2004
DragonAce's Avatar
DragonAce is an unknown quantity at this point
question..
why you wanna run the second 0 gauge ground thru the firewall??
is yer battery still located under the hood??
if so it's better to keep the 0 gauge ground as close to the amps as possible..it doesn't have to go back to the battery
Old Nov 7, 2004
MegaHurtz's Avatar
Yeah that is a good point... you only need to pull one wire through, i missed where you said power AND ground.
you should be able to fit 1/0 thru the grommet, so no drilling necessary
Old Nov 7, 2004
DragonAce's Avatar
another thing..
0 gauge'll run down the side no problem, but be prepared to cut out the little plastic bits on the bottom side of the sill cover unless ya wanna bubble up your carpet (looks cheezy with carpet bulging)
been thru the 0 situation twice, once rectangular wire and then rounded..
Old Nov 7, 2004
civic01vtec's Avatar
Originally Posted by DragonAce
question..
i agree....i would only pull 1, 0 gauge wire through.
Old Nov 7, 2004
Yeah, the reason I wanted to return to the battery is because I have my system currently grounded to the frame, about 2 feet from the amps, but I'm still getting very small amounts of alternator whine. I was hoping that returning the ground to the battery would help this problem.
Old Nov 7, 2004
ohiojosh78's Avatar
ohiojosh78 can only hope to improve
have you upgraded the wire from the battery to the frame inside the hood? If not that will clear it up
Old Nov 7, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Grounding kit. Derek had one for sale a while back, don't know if he still has it.
Old Nov 7, 2004
ohiojosh78's Avatar
No kit. Just buy like 2' of wire and upgrade from the battery to the body. thats all you'd need to see if it will work. dont need all that other crap when your only concern is the alt noise.
Old Nov 7, 2004
May as well do it right the first time.
alinaray
18
Aug 24, 2015 01:04 PM
honda.lioness
Aug 21, 2015 02:36 PM
Wolfcamp
Aug 14, 2015 08:52 PM
BrandonD
Aug 9, 2015 10:22 AM
barryaz1
Jul 30, 2015 10:50 AM
