Sponsored by:
Sponsored by: CARiD
shift knob install
Old Nov 4, 2004
hman913's Avatar
hman913 is an unknown quantity at this point
shift **** install
(yes I used that handy little search button)
I just my RSX shift **** yesterday and while trying to put it in, I realized it's a bastard. The first of the threads start to bite into the ****, then it immediately starts going on crooked. And it's only the first couple threads that actually bite. Is there a certain way to put it on? And do I need the clip to hold up the boot?
Old Nov 4, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
Old Nov 4, 2004
zen_master's Avatar
ok dude....you should not have any problem installing that shift **** into ur shifter...
it's a perfect fit....perfect thread....is there any problem with the shift **** before u install it? probably u did it too fast?
the shift **** itself will also clip into the silver ring perfectly..
Old Nov 4, 2004
Mr.Modify's Avatar
yea the RSX Shift **** will go on perfectly....i have the Type -S one....you need to try it again. Clips on to the stock clip perfectly
Old Nov 4, 2004
dma001's Avatar
dma001 is an unknown quantity at this point
I have the base (5-speed) RSX ****, and I didn't have any trouble with the installation, but I remember I started and backed it off a couple times before I cranked it down to make sure I had the threading right.
Old Nov 4, 2004
Atticus's Avatar
Atticus is an unknown quantity at this point
user error
Old Nov 4, 2004
hman913's Avatar
I was just working on it again and no dice. I doesn't just slip on and able to be screwed on. The hole on the **** is 0.35" and this continues for about 1.5", and none of it is threaded. After the 1.5", threading starts but the diameter decreases so there's no way that can screw on.
What's the deal?
Old Nov 4, 2004
Da1lyDr1ver's Avatar
do you have the base rsx **** thats made out of rubber or the metal looking one? the black one should fit with no problems. but the metal one is not going to fit perfectly and you'll need to get another clip to fit the shifter if you want to keep the silver ring.
Old Nov 4, 2004
hman913's Avatar
It's the base rubber one with the bit of silver down the center.
Old Nov 4, 2004
txc2929's Avatar
txc2929 is an unknown quantity at this point
Anyone know where I can get a clip to hold up the boot from? I emailed hondawerx last week or something and no reply. Just got my Skunk2 **** and now my boot sits too low. Let me know. Thanks
Old Nov 4, 2004
hman913's Avatar
Try that little button that says "Search" it works wonders
Old Nov 4, 2004
03HondaEx's Avatar
03HondaEx is an unknown quantity at this point
http://www.7thgencivic.com/forums/sh...d.php?t=132538
That is the tech section that gives you what part number you need to order the plastic ring that holds the boot up.
Old Nov 5, 2004
Shifter's Avatar
Shifter is an unknown quantity at this point
Try a bolt.
See if you can get ahold of an M10 x 1.5 screw/bolt that's at least 50mm long. Now see if you can thread it into the ****. It'll be much easier to clean a minor burr in the **** by using a screw/bolt. If worse comes to worse, you may need a tap, but it's unlikely that the **** threads are that messed up.
Good luck!
Old Nov 5, 2004
jameStype's Avatar
jameStype is an unknown quantity at this point
yea, it sounds like he stripped the threads. i have the base rsx shift **** on my baby and i took it slow. it fits like a glove and it feels a lot more comfortable than the vic's stock counterpart. i'll have to try the revo ss kit next when i get around to it.
Old Nov 5, 2004
hman913's Avatar
The **** was for an AT, and all has been righted by Dezod. Damn I love the feel of the MT RSX ****.
Old Nov 5, 2004
jameStype's Avatar
you put an mt rsx shift **** on an automatic vic? can you provide pics. never seen that combo done before. sounds interesting.
Old Nov 6, 2004
hman913's Avatar
No I put an MT RSX **** on an MT civic
Supramk3
Jun 11, 2015 11:13 AM
What_It_Do
May 10, 2015 05:31 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
NukeSilo
Nov 20, 2001 10:02 PM
StLVtec
Nov 14, 2001 09:22 PM
