shift knob install
shift **** install
(yes I used that handy little search button)
I just my RSX shift **** yesterday and while trying to put it in, I realized it's a bastard. The first of the threads start to bite into the ****, then it immediately starts going on crooked. And it's only the first couple threads that actually bite. Is there a certain way to put it on? And do I need the clip to hold up the boot?
ok dude....you should not have any problem installing that shift **** into ur shifter...
it's a perfect fit....perfect thread....is there any problem with the shift **** before u install it? probably u did it too fast?
the shift **** itself will also clip into the silver ring perfectly..
yea the RSX Shift **** will go on perfectly....i have the Type -S one....you need to try it again. Clips on to the stock clip perfectly
I have the base (5-speed) RSX ****, and I didn't have any trouble with the installation, but I remember I started and backed it off a couple times before I cranked it down to make sure I had the threading right.
I was just working on it again and no dice. I doesn't just slip on and able to be screwed on. The hole on the **** is 0.35" and this continues for about 1.5", and none of it is threaded. After the 1.5", threading starts but the diameter decreases so there's no way that can screw on.
What's the deal?
What's the deal?
do you have the base rsx **** thats made out of rubber or the metal looking one? the black one should fit with no problems. but the metal one is not going to fit perfectly and you'll need to get another clip to fit the shifter if you want to keep the silver ring.
It's the base rubber one with the bit of silver down the center.
Anyone know where I can get a clip to hold up the boot from? I emailed hondawerx last week or something and no reply. Just got my Skunk2 **** and now my boot sits too low. Let me know. Thanks
http://www.7thgencivic.com/forums/sh...d.php?t=132538
That is the tech section that gives you what part number you need to order the plastic ring that holds the boot up.
Try a bolt.
Good luck!
yea, it sounds like he stripped the threads. i have the base rsx shift **** on my baby and i took it slow. it fits like a glove and it feels a lot more comfortable than the vic's stock counterpart. i'll have to try the revo ss kit next when i get around to it.
Supramk3
Jun 11, 2015 11:13 AM
What_It_Do
May 10, 2015 05:31 PM
toastyghosty
32
Dec 26, 2001 02:03 AM
NukeSilo
Nov 20, 2001 10:02 PM
