K20 Swap Problems!!!! Please Help!!!
Old Sep 30, 2004
disnikhavikta's Avatar
disnikhavikta is an unknown quantity at this point
Angry K20 Swap Problems!!!! Please Help!!!
we juss finished my type s swap into my 02 civic ex coupe and everything is fine, i got spark, fuel pump works, voltage everywhere but for some reason the fuel will go to the fuel rail and juss stop there, for some reason my injectors wont open up, and we tested the injectors and they are good. We also have the type s key, ignition, and ecu so we dont have to re flash anything. does any one know what the problem could be/????? we been tryin to find out for the past week. basically there is no fuel going to the motor, it cranks and everything but the injectors wont open up. ANY HELP WOULD BE HELPFUL THANKS.
Old Sep 30, 2004
scorpion232's Avatar
scorpion232 is an unknown quantity at this point
call import options in hayward california i do not know the nuber off had but they speciallize in engine swaps only into hondas it's either hayward or san leandro
Old Sep 30, 2004
i will try to find the number for you
Old Sep 30, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Gotta be a harness issue, or the ecu isn't sending the signal to the injectors...
Old Sep 30, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
did you have hasport make your harness
Old Sep 30, 2004
thanks alot scorpion, i really need some help with this. we didnt have hasport do the harnest but we had the diagram to do it. the only problem is the injectors that wont open to give fuel.
Old Sep 30, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
sounds like a wiring issue.. i'd double check that
Old Oct 1, 2004
atl01's Avatar
almost deffiently a wiring issue, just go back and check ALL your wiring, maybe try giving hasport a call maybe they can help you out.
Old Oct 1, 2004
Hawk's Avatar
You boost, I-VTEC
USE THE HASPORT HARNESS! I had the same problem with my car when i tryed to do my harness myself. Hasport knows what they're doin it's worth the cash.
Old Oct 1, 2004
whitevic's Avatar
whitevic is an unknown quantity at this point
Double check all of your wiring. I have had no problems of this sort, and I did my harness.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
jmdcivic
May 20, 2015 09:52 PM
SoyerOner
May 11, 2015 09:46 PM
usajags84
May 10, 2015 08:11 AM
Chronic_issues
May 8, 2015 05:40 PM
