Turbo Specialitis Inc....
Old Sep 28, 2004
TRANX's Avatar
Don't Let Your Future Be Destroyed By My Past...
TRANX is a glorious beacon of lightTRANX is a glorious beacon of lightTRANX is a glorious beacon of lightTRANX is a glorious beacon of lightTRANX is a glorious beacon of lightTRANX is a glorious beacon of light
I was surfing the superstreet.com page and i found this..hopefully it will help those of you that want a turbo and hope is not a repost.....
TRANX.
Turbo Specialties Inc. Turbo Kit for the 2001+ Honda Civic 1.7L
167 hp and 160 ft/lbs at the wheels!
Turbo Specialties answers the D17 Cognoscenti
Turbo Specialties, Inc and Turbo-Kits.com have answered the demand of all the red-headed stepchildren (otherwise known as a 2001-and-up Civic owners) by developing a new bolt-on turbo kit for the underpowered 1.7L SOHC. The fast-spooling T25 turbo allows the 1.7L to belt out 167 hp and 160 ft/lbs at the wheels or 200 hp and 192 ft/lbs measured at the crankshaft. These figures are made at only .4 bar (6 psi). Full boost is reached at 2500 RPM. This turbo kit will not win any dyno wars or make you a hero on Honda-Tech.com, but it will produce enough power and torque to make your drive more enjoyable, while still giving you the ability to drive it everyday. Like many factory turbocharged vehicles, you can upgrade the system by swapping out the T25 with the higher-flowing T28 Ball Bearing turbo which will give you 325-350 hp at the wheels (with proper tuning).
Included in the kit:
Garrett T25 Turbo
TSI Cast Iron Manifold
Heat Shield
2" Downpipe w/ Gasket
Map Box
APEX'i VAFC
TSI Blow Off Valve
APEX'i Turbo Timer
Boost Gauge
TSI High Flow Front Mount Intercooler
Polished Charge Piping
Air Cleaner
Stainless Steel Braided Turbo Water Lines
Stainless Steel Braided Oil Line
Oil Return Hose & Fitting
All Necessary Clamps, Gaskets, Fittings & Hoses
Source
Turbo-Kits.com
e-mail: info@turbo-kits.com
phone: 860-735-6519
Cost: $2899
Optional T28 Full Ball Bearing upgrade: +$500
*Kits are stocked and ready to ship
Old Sep 28, 2004
Havok2k1's Avatar
Wicked Pissah Admin
repost, 7 posts down
http://www.7thgencivic.com/forums/sh...d.php?t=173373
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
MamaBear2015
Sep 4, 2015 09:04 PM
justcruzin125
Aug 11, 2015 09:09 PM
