turboing D17A2
Old Sep 25, 2004
bradmanuwf's Avatar
bradmanuwf will become famous soon enough
turboing D17A2
I am turboing my 03 ex and just have some questions.
1. How many cc's are the stock injectors and what would be a good size to get for 6-7 psi?
2. Has anyone had any experience with a map unit called "Missing Link" that keeps the ecu from detecting boost? "Missing Link" MAP unit
3. Does anyone know where I can get some information about converting from a returnless fuel system to returnable? I've seen it but don't know how it was done.
4. Will injectors from a b series work in d17?
5. Will an SAFC-II, bigger injectors, and the map unit keep my engine running well at 6-7 psi? I want the engine to last a long time. Detonation is bad!!!!
Old Sep 25, 2004
The vendor streetlevelperformance on this site is selling return conversion fuel kits I believe. Good tuning for turbo would be the greddy e-manage. Alot of boosted guys also use this thing to send the ecu a fake signal so that the tuning can actually work without the ecu resetting everything.
http://www.splitsec.com/products/conditioner.htm
Old Sep 25, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
im not sure about the stock injector size, but i along with other countless poeple r running 9 psi off the so there's no need to upgrade.
b-series injectors will not work but the k series will but u have to modify your rail a lil cuz there longer.
what do you wanna know about converting the fuel lines i have one
as long as u tune everything properly you shouldnt have any engine problems. with our cars its all about tuning!!!!
btw: my kits for sale...
http://www.7thgencivic.com/forums/sh...d.php?t=173761
Old Sep 25, 2004
civic01vtec's Avatar
1) stock injectors are 240cc
2) Everyone uses the ML........welcome the world of boost
3) returnless fuel system.........search ........if you want a compete bolt on kit, then contact jeff at www.streetlevelperformance.com
4) injectors from a b series motor will not work.......but rsx-s injectors will fit, they are rated at 340cc
5) stay away from a safc as it has been shown to advance the ignition timing. Get the e-manange and harnesses to get the best out of your motor.
Old Sep 26, 2004
GLi4dr's Avatar
GLi4dr is an unknown quantity at this point
Does the E-Manage have the Vtec controller?
I want to do the Vtec head swap and I see there is a diy
using the vafc, now, if I dont use that, what will controll the
Vtec?
Old Sep 26, 2004
yes it does but i dont know if any one got it to work right with i vtec...
Old Sep 26, 2004
GLi4dr's Avatar
Thats okay, I don`t want it for i-Vtec...Just for the Vtec on the
D17a...
Thanks
Old Sep 26, 2004
D17a...
Thanks
it works, but nobody on here got it to work correctly
btw, a vtec head swap on a sohc motor is a waste of money IMO.........that money could be better off spent on pistons and rods.
Old Sep 26, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
For some damn reason my EX turbo kills my budies LX turbo. PSI for PSI both with t3 turbos. There is something there. Dont realy understand why. There just is a difference. VTEC opens the exhaust valves a little more.
Old Sep 26, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
That is incorrect. Only one intake valve is affected when vtec is engaged.
Old Sep 26, 2004
guns's Avatar
Skyline R33
Are you sure. My shop who installed my cam told me that it looked like vtec just opened the exhaust side higher.
Old Sep 26, 2004
They were looking at it wrong.
Old Sep 26, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
4drcivic2k1 is right. I just looked in my service manual to double check. VTEC only messes with the intake on the D17's.
Old Sep 27, 2004
guns's Avatar
Skyline R33
I stand corrected. SO it lets more air in. Interesting. No wonder I was running soo rich when my vtec was not plugged in?
Old Sep 27, 2004
GLi4dr's Avatar
Would that have something to do with compresion ratios being different??
I cant get the civic in Vtec here in oz, only this gay looking 5 door hatch comes with the d17a2, thats why I want to do the swap. I have read that the Vtec kicks harder when you do the head swap.
So basically any computer system that changes Vtec can be used to do the head swap, yeah??
Old Sep 27, 2004
vtec lifts only the intake valves on all honda motors
Old Sep 27, 2004
bradmanuwf's Avatar
Should I get saturated injectors or peak and hold injectors for turboing my 03 civic? Do you think 310cc or 370cc would be good size?
Old Sep 27, 2004
hmmm........90% of all cars are using sat injectors
unless you are gonna have very high fuel pressure (around 100psi) then i suggest sat injectors.
Most ppl, including myself are using rsx-s injectors which are 340's but have been flow tested around 320 or so.
Old Sep 27, 2004
bradmanuwf's Avatar
are rsx(k20) and rsx-s(k20a) injectors the same size? I've been told you have to modify the fuel rail, how so?
Old Sep 27, 2004
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
I Have RSX-S Injectors there was no need to modify the fuel rail. And the K20A3 (Base rsx) have 270cc injectors and the K20A2 (RSX type S) have 310cc or something like that.
Old Sep 28, 2004
you will need longer bolts and spacers, since the type s injectors are longer
Old Sep 28, 2004
That is also incorrect. On a DOHC VTEC b series both sets of valves are actuated.
Old Sep 28, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
RSX and RSX-S are a little bigger.. around 320 or so, if i'm not mistaken.. (opto isolator (thank the lord for this guy) had them flow tested and everything so pm him if you need more info)
I go to UWF too.. maybe i'll see you out there soon.
Old Sep 28, 2004
Crackhead79's Avatar
nice info guys thank you , I hope to be boosted here soon as well if not for Dezod then any of the guys selling the SF kits, but can't wait! I just hate hearing from so many that boosting my car isn't worth it, forget that, if its what I can do I will, thanks guys, laters...
Old Sep 29, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Negative on MOST DOHC VTEC Honda motors VTEC is both on the intake and exhaust valves...
Old Sep 30, 2004
bradmanuwf's Avatar
this thread was not for talking about VTEC. it was for talking about turboing the d17.
Old Sep 30, 2004
guns's Avatar
Skyline R33
It is all info wich will help you better understand how the engine works and what mods do what.
VTEC Maing!!1
Old Sep 30, 2004
TheSmuggler's Avatar
Hey, I don't care if you started it were jacking it!!! LOL, j/k
Old Sep 30, 2004
Guns it's V-TACH lol ... duhhhh
Old Sep 30, 2004
guns's Avatar
Skyline R33
Dude you cant even spell. fawkin NOOB> its V-TECH stand for vroom-technology
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
