broke down, turbo problem
Old Sep 21, 2004
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
ok so i installed my SF turbo a few days ago and im crusin tonite and i come up to a red light and my car starts choking up on itself and cuts off, so i started it back up and it sounded like it was misfireing so i putted off to the side and popped the hood. nothing seemed wrong so i tried starting it and it would just putter and cut off, so i disconnected the charge pipe and started it NA and still had the same problem. i cant get it towed, so i just started driving it and after about a mile it cleared itself up, i drove home with the pipe disconnected and everything seemed ok...im thinkin the MAP sensor saw boost and went crazy because i have the SF check valve in there, and after it saw regular VAC it cleared itself up. so i ordered the missing link from dezod, hopefully that will solve the problem, anyone have any suggestions.????
Old Sep 21, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Humm, yeah I would try the missing link over the one sf provides. Are you using any fuel managment such as the emanage? ALso what spark plugs are you using?
Old Sep 22, 2004
robo1040's Avatar
no i have no fuel management as of right, now, i just got my kit on 2 days ago. i am running the ZEX nitrous plugs because i had them in when i was running my nitrous kit, thought they would be good with the extra heat? im goin to my shop this morning to plug it in and see what i get.
Old Sep 22, 2004
robo1040's Avatar
ok i found the problem, busted spark plug on the number 1 cylinder. i def had a misfire
Old Sep 22, 2004
gotti's Avatar
if you're leaking oil or have a lot of blow-by, then u fried your pistons and or rings. I had the same exact probem.
Old Sep 23, 2004
robo1040's Avatar
dude my turbo smokes like a bitch, i definitly know there is oil leaking inside of it, that wouldent cause the pistons to go would it? also, what blow-by?
Old Sep 23, 2004
HyaBoosta's Avatar
I don;t think it was a busted spark plug because if it was then it wouldn't have cleared up after removing the charge pipe.
Old Sep 23, 2004
robo1040's Avatar
yeah i was thinkin that too, the reason i think it didnt stall out when i took the charge pipe off was it was gettin better air flow, which was atleast lettin it run a little better, enough not to stall out while it was sitten there. and as far as it clearin up while it was driving i think if i forced it to drive with the pipe still connected it would have done the same thing, the ecu just had to learn how to run the motor on 3 clyinders
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Tommy Cohen
Jun 14, 2015 10:36 PM
Supramk3
Jun 11, 2015 11:13 AM
4 banger
Jun 5, 2015 01:44 AM
mikevtec
May 3, 2015 01:36 PM
