blacking out the headlight housing
Old Sep 21, 2004
pupil george's Avatar
pupil george is an unknown quantity at this point
ok i searched and read every topic and diy on this but i need to find out oen hting when u pu them in the oven do u pu tthem on anythign or jsut set them in the oven by themselfs
Old Sep 21, 2004
jkob2k1's Avatar
jkob2k1 is an unknown quantity at this point
The headlights should come off easy without heating them when i did mine i just cut the silicone with a razor. Are you doing the oem headlights or projectors?
Old Sep 21, 2004
Mr.Modify's Avatar
do you have a 04? if so yea those things are hard to get open but what i did instead was use a blow dryer to heat them up at one point of the lights and started prying with a screwdriver.......but yea to answer your question....just stick em in there maybe with like a pan under it.
Old Sep 21, 2004
thanks alot i have a 03
Old Sep 21, 2004
Honda2k4's Avatar
Honda2k4 is an unknown quantity at this point
those things are a btich to get apart
Old Sep 22, 2004
SiG's Avatar
SiG
i did mine this past weekend, and i too have a 2003
I put them on a pizza tray, at 200 degrees celcius for 50 seconds
they werent too hot when i took them out. then, i pryed the lights apart. it was black sealant that was holding the lights together
Then i sanded off the chrome, and painted the sanded parts with a flat black, heat resistant paint. If ya wanna ask any more questions, feel free to PM me and ill gladly help ya out.
If ya wanna see pics of how they turned out, check them out at
http://www.cardomain.com/memberpage/691719
Old Sep 26, 2004
jkob2k1's Avatar
You dont really have to sand off chrome just clean surface really good with rubbing alcohol and paint.
Old Sep 26, 2004
Mr.Modify's Avatar
werd!
Old Sep 26, 2004
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
they are really easy. Just take an exacto knife and slice around the black sealant stuff. Then once you work a small screwdriver into it, its very easy to pry them apart. I just cleaned the chrome and painted it with regular black paint (not hi temp). They look p.i.m.p. now. Really no reason to bake them.
Old Sep 26, 2004
Cyberkinetic's Avatar
Cyberkinetic is an unknown quantity at this point
I cleared my headlights months ago, but now I want to blackhouse them. If any of you have pics, can you post them? Especially if you have a blue car! I wanna get an idea of what mine would look like.
Old Sep 29, 2004
HyaBoosta's Avatar
so how many people sanded the chrome and how many didn't. because we tried this before on headlights from a wrecked civic and when we taped it off and painted it. once we removed the tape, the chrome peeled off with it.
Old Sep 29, 2004
jwalker87's Avatar
Bodacious Member
i didnt. Then again, with our headlights, you dont need tape. The entire trim piece can be painted black, and it looks good, so there's no chance of taking chrome off with the tape.
Old Sep 29, 2004
HyaBoosta's Avatar
but what about the rippled chrome section where the headlight bulb is and the circles where the bulbs all go? don't you need to cover them up?or does that come off too?
Old Sep 29, 2004
chicohonda02's Avatar
Since 2002 Baby!
ya! i was wonding that too. I would like to paint the headlight too, sooner or later.
Old Sep 29, 2004
jwalker87's Avatar
Bodacious Member
that comes off. You dont need to sand it. There's a DIY on this site that shows a picture of the headlight disassembled. Here it is:
It should show that the entire trim piece can be painted black.
Old Sep 29, 2004
HyaBoosta's Avatar
so what kind of paint have you guys used?would just some spray paint work?
Old Sep 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Pick up some Krylon Fusion spray paint from your local Home Depot. It's supposedly made to bond to plastic (which these "chrome" parts really are) without sanding or priming. It's worked great in a dozen or so headlights I've done.
Old Sep 29, 2004
HyaBoosta's Avatar
nice. thanks for the help guys. Im going to do this this weekend. Im getting a little bored of the cleared lights and blue painted dash trim pieces. Im going for the stock sleeper look. so im gonna black em out and paint the trim pieces black again.
what do you guys think on a black coupe. flat black or shiney.
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
Kyles24
Jul 12, 2015 09:15 PM
ZILLA
Air Conditioning
Jul 11, 2015 08:35 PM
BootyDo
Jul 7, 2015 06:06 AM
