Inverter Hookup - Turning on and off via ignition.
Old Aug 25, 2004
909's Avatar
909
909 will become famous soon enough
I plan on installing an inverter in the trunk 12VDC to 120VAC.
--- The wattage options will be 200W, 300W, 700W (undecided).
How can I safely connect the inverter so its controlled by the ignition?
What size of wire should be used ?
Currently there is a 4 guage power wire from the battery
running from the head unit powering an alpine amp.
Old Aug 25, 2004
MegaHurtz's Avatar
Use a relay and tap a switched 12v wire to turn the invertor on when you turn your car on
Old Aug 25, 2004
909's Avatar
909
I don't want to accidentally leave it on while the car is parked. It _must_ not be able to power on without the key.
After more research, from what I understand, we can tap into IG1 from under the steering column (black w/ yellow stripe). Can someone confirm this? Where would the relay go?
Old Aug 26, 2004
Ed's Avatar
Ed
you shouldn't have to go all the way down there, if you have an amp already, you can tap the remote line, or just tap the cig lighter. Run a line, somethign small, 18 ga or so from the cig lighter, connect that to the relay where your invertor is and have the relay switch the power wire on and off.
Old Aug 27, 2004
909's Avatar
909
Makes perfect sense. Can you show me a simple example, something I can visualize?
Accessory line to switch is no good because it turns _off_ during crank.
bake
Sep 26, 2005 10:54 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
TopFuel
Nov 21, 2001 02:17 PM
locozoko
Nov 8, 2001 06:33 PM
