MA Amps...?? Ever heard of them
Senior Member
Are MA Amps any good I am looking at one MA HK-597 it is rated at 4 X 200 wrms @ 4 OHMS. I find that kinda hard to beleive. I was wondering if any of you guys have heard of the company and how good these amps really are. I am looking to replace my sh?tty Kenwood KAC 646 (35 max X 4) for my incar speakers.
I am not looking for recommendations of other amps, just on what you guys think of this amp.
Doubtful... judge the probable power output based on a few things:
1) Price. A more expensive amp will be more likely to put out it's claimed power than a dirt cheap amp. Price isn't everything but it will give you a good indictation.
2) Physical size. An amp that is 6"x12" won't put out 200x4 in a million years. Again, size isn't everything but it will give you a good indication.
3) Fusing. An amp with 20-30 amps of fusing on it obviously is not designed to put out 200x4. You will need a lot of current to generate that kind of power so make sure the amp is fused accordingly.
And that RMS power is probably at 14.4 volts, I doubt any car runs a constaint 14.4 volts. so the amp probably is only pushing about 100- 125 maby at 12.5 13 volts. Im probably off a little but it gives you an idea. JL is an amp that will put out 500 rms at 11.5-14.4 volts, you donot lose power.
I just talked to my buddy who used to work for MA and he says that amp puts out around 60x4 before it starts clipping
He also said it's a POS, so don't buy it. This guys opinion is worth trusting
Electric Boogaloo...
Price isn't a good indicator. JBL amps put out their rated power, yet are able to be had dirt cheap.
Physical size also isn't a good indicator. I have an old Fosgate amp that's about that same size that easily puts out 600-700 watts. Back when they made them worth a crap.
Originally Posted by WildRice
200W RMS Is very doubtful, I have never seen an amp that creates that much power unless it was created by God himself.
arc amps are pretty small and pack quite a punch. then again, i've seen some pretty big zapco and ppi amps that weren't super powerful (weren't designed to be either).
MA audio comes from a company that largely makes crap.
Senior Member
Ok so what brands should I be looking at for a 4 channel - dont have room for a huge amp on my board. Currently I have a KAC 646 so I need the new amp to be around that size, any suggestions? MTX404? I got infinitiy 605 comps and infinitiy 62.5 in the rear
Lightning Bolt B2.400.4?
brags
Oct 2, 2015 05:53 AM
curaze
Sep 22, 2015 08:27 AM
jerry38
Sep 20, 2015 08:38 AM
