Which Crossover ot use
Senior Member
I have a Alpine CDA 7998, I am just wondering where I should be setting the crossvers from: My headunit or on the amp it self or a combination of both? If it is one or the other should the other's crossover function be set to off?. My AMP is the kenwood KAC 646X
Use either one or the other. If you use one shut the other off
Might be more convenient to use the one on your head unit and run the amps full range as you will have the controls right at your fingertips
Slickwillie
Jan 24, 2002 06:39 PM
