Which Crossover ot use
Old Aug 24, 2004
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
I have a Alpine CDA 7998, I am just wondering where I should be setting the crossvers from: My headunit or on the amp it self or a combination of both? If it is one or the other should the other's crossover function be set to off?. My AMP is the kenwood KAC 646X
Old Aug 24, 2004
MegaHurtz's Avatar
Use either one or the other. If you use one shut the other off
Might be more convenient to use the one on your head unit and run the amps full range as you will have the controls right at your fingertips
Jeffdp
Aug 5, 2015 11:38 AM
ZSKCivic01
Mar 8, 2003 05:39 PM
ZSKCivic01
Feb 21, 2003 10:03 PM
NeonNights
Mar 22, 2002 11:44 AM
Slickwillie
Jan 24, 2002 06:39 PM
