03 coupe- koni shocks only option?
Old Aug 20, 2004
winnerpl's Avatar
winnerpl is an unknown quantity at this point
Hey guys I wanna lower my 03 coupe with eibach sportlines, and want to get the new shocks so I don't have to worry about blowing them. I'd get the tokico blues but drilling is involved in installing the front ones and I'd rather avoid them. Am I stuck with the koni yellows? They're a bit expensive for my budget.
Old Aug 20, 2004
scbgilbert's Avatar
scbgilbert is an unknown quantity at this point
i have the similar drop with my evotion springs (race drop 1.5" - 2.5" ... but i am using stock shocks right now and i was looking for shocks also ... koni makes either has the adjustable yellow shocks (which you might have to worry about the adjusting **** seizing up after a year or two if you don't regrease them), or just the sleeve inserts (which you won't have to worry about one bit). But if you decide to change to a sport drop (1" - 1.5") you will not have to worry about getting any type of shocks, because you can get by with your stock shocks.
Old Aug 20, 2004
kpyoungin's Avatar
New Member
kpyoungin is an unknown quantity at this point
^wrong. koni yellow's are adjustable. front's are inserts, rears are full replacement shocks. they're all adjustable though..
Old Aug 20, 2004
streetglower's Avatar
I am not sure what your talking about, there is only one type of koni shock for our car. The fronts are inserts and the rears are just replacements.
I have eibach sportlines and koni yellows and I have had them for almost 8 months now and they are great. The only down side is the fronts are inserts to the original honda housing, but the rears you just swap out. And they are adjustable which makes them nice.
pretty much thats your only option. They have one type of KYB shock out now, but it is like a OEM replacement and really not made for lowered cars. Also you can go several yrs on sportlines and not blow your OEM shocks, it is all how you drive. If you drive slow over speed bumps and not take corners fast, you will be fine for a while.
Old Aug 20, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You need to gut the front strut out to put the koni insert in. So drilling the mounting bracket holes isn't really that big of a deal. If you just need to drive on the street, get the tokicos, and find a machine shop or someone with a drill press who can bore the lower bracket holes out to 16mm.
Old Aug 21, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
Your bumpstop will not fit correctly as the tokico front strut rods are smaller than oe on a 2003. I just tightened my bumpstops with wire.
Old Aug 25, 2004
phatcyclist's Avatar
phatcyclist is an unknown quantity at this point
wow, why are there no options for the 03s and up? If the KYB AGXs end up only being for the 01-02, Im selling my car and getting something else, its freaking rediculous. I guess the Hayame v2s fit, but no one is having any luck with them, and going and buying new knuckles is yet another $300 on top of the cost of suspension. I guess its sort of not worth it to drop an 03+.....
Old Aug 25, 2004
There are alot of options. Any lowering spring will work, and with the shocks, any will work, yes each require some type of modification, but it isnt anything major. There are also full coilovers, teins, tein ss, B&G's, dropzone, omni. So you arent out of the loop.
Old Aug 25, 2004
well, Tire rack says there are two types of Konis, the 50.5mm kind and the 53.8mm kind, which kind would I want for an 03?
Old Aug 25, 2004
Well there should only be 2 sizes, 50mm and 55mm. To be sure which ones you need, measure your front strut housings. I think the 03 civics have 55mm, but I could be wrong. I just went ahead and got mine without measuring and everything was fine.
Use a dial caliper and measure around the housing to get the correct size you need.
Old Aug 26, 2004
dvsdara's Avatar
dvsdara is an unknown quantity at this point
You'll need the 55mm ones. Tirerack has the size down wrong. I have an 03 also and I needed the 55mm. The 50mm are too small. I ordered without measuring and had to wait an extra 2 weeks to deal with returning and then getting the right ones. They mixed it up in 2002 with the 50mm and the 55mm. People with 02 pretty much have to measure for sure. For us 03, I believe its 55mm on all of them, but then again I'd check just to make sure.
Old Sep 2, 2004
topnotch7gen's Avatar
JDM-Jonathan David Martin- I own everybody
topnotch7gen is on a distinguished road
man I say go with the Koni's, they ride like a champ on my car and I have progress springs with them, my car can take corners/parking lot medians like their nothing. Great shocks to buy!
Old Sep 4, 2004
JDMVTECB20's Avatar
JDMVTECB20 is an unknown quantity at this point
try tokicos, also good with eibach springs! or you can just go with what i got... full tein (EH HEMM... THE BEST!)
Old Sep 5, 2004
gotrice's Avatar
gotrice will become famous soon enough
where did most people buy their koni's and price
Old Sep 13, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
I have a 03 coupe Which shocks can I get that bolt on with no mods
Do I need 50mm 55mm
Old Sep 13, 2004
dvsdara's Avatar
IF you get Koni you will need the 55mm. I have a set that I will be selling once I get the front ones replaced. I have about 800 miles on the rear and that's it. I switched over to coilovers cuz I wanted to be lower than 1.3" around with the H&R Springs. I also wanted to raise it back up a bit for the winter too. If you're interested, PM me man. We'll talk.
Tedverseti
Apr 23, 2020 01:45 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Tedverseti
Sep 29, 2015 05:41 PM
Bruce2
Sep 27, 2015 08:45 PM
