03 coupe- koni shocks only option?
Hey guys I wanna lower my 03 coupe with eibach sportlines, and want to get the new shocks so I don't have to worry about blowing them. I'd get the tokico blues but drilling is involved in installing the front ones and I'd rather avoid them. Am I stuck with the koni yellows? They're a bit expensive for my budget.
i have the similar drop with my evotion springs (race drop 1.5" - 2.5" ... but i am using stock shocks right now and i was looking for shocks also ... koni makes either has the adjustable yellow shocks (which you might have to worry about the adjusting **** seizing up after a year or two if you don't regrease them), or just the sleeve inserts (which you won't have to worry about one bit). But if you decide to change to a sport drop (1" - 1.5") you will not have to worry about getting any type of shocks, because you can get by with your stock shocks.
I have eibach sportlines and koni yellows and I have had them for almost 8 months now and they are great. The only down side is the fronts are inserts to the original honda housing, but the rears you just swap out. And they are adjustable which makes them nice.
wow, why are there no options for the 03s and up? If the KYB AGXs end up only being for the 01-02, Im selling my car and getting something else, its freaking rediculous. I guess the Hayame v2s fit, but no one is having any luck with them, and going and buying new knuckles is yet another $300 on top of the cost of suspension. I guess its sort of not worth it to drop an 03+.....
well, Tire rack says there are two types of Konis, the 50.5mm kind and the 53.8mm kind, which kind would I want for an 03?
Use a dial caliper and measure around the housing to get the correct size you need.
JDM-Jonathan David Martin- I own everybody
man I say go with the Koni's, they ride like a champ on my car and I have progress springs with them, my car can take corners/parking lot medians like their nothing. Great shocks to buy!
IF you get Koni you will need the 55mm. I have a set that I will be selling once I get the front ones replaced. I have about 800 miles on the rear and that's it. I switched over to coilovers cuz I wanted to be lower than 1.3" around with the H&R Springs. I also wanted to raise it back up a bit for the winter too. If you're interested, PM me man. We'll talk.
Bruce2
Sep 27, 2015 08:45 PM
