Faceplate Relocation
Old Aug 16, 2004
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
My question is on relocating the headunit, and no its not about moving it by the cigarette lighter like everyone else asks. I'm placing my radio faceplate on the headliner behind the map lights, and keeping the radio itselft in the dash kinda where it would normally go back there. I've seen a picture of somebody do this and i believe ludlam has done it as well. I've already extended wires between the faceplate and radio.
The problem I'm having though is that the length of wire between the two seems to be too much and is creating too much resistance for it to work. When I shortened the length to say about a foot it works fine, but when I extend it to the length I need it just flickers. I've used ethernet cable as I believe other people have done for this. So my question is if you've done this, what type of wire did you use and how long was your distance, and if you had to use anything else to get it to work. Thanks.
Old Aug 16, 2004
MegaHurtz's Avatar
Ethernet cable should theoretically work, are you sure there is not a break in the cable that you are using?
Unless only extremely small amounts of voltage and current are running thru the wires, ethernet should be good enough.
Maybe try somethng a little bigger, like say 20 or 22 awg wire?
Old Aug 16, 2004
thanks for the help, what guage is ethernet wire anyway? Theres a guy here installing an alarm in my house and he just went to lunch so i checked out if he had any good wire down there. Hes got one thats ethernet style with 12 wires in it and its labeled 22 awg. Is ethernet 24awg? I just wanna make sure this wire will actually be a lower gauge.
Old Aug 16, 2004
MegaHurtz's Avatar
Ethernet is probably 22 or 24 gauge... not sure which
Old Aug 16, 2004
Flounder's Avatar
Flounder is an unknown quantity at this point
Ethernet AWG
Cat5 is 24AWG.
-Flounder
Old Aug 17, 2004
thanks for the help, i'm in the process of soldering on all the new wires, its a huge pain.
Old Aug 17, 2004
DrivenConcepts's Avatar
Don't Listen To What Anyone Says, It's Ok To Be Jealous
DrivenConcepts should not be trusted
has anyone actually move there radio to the cigarette lighter place??
Old Aug 17, 2004
yea.. look at derek's ride..
http://www.7thgencivic.com/memberrid...cat/500/page/2
that one shows it..
Old Aug 17, 2004
how did he fit it in there do you know??
Old Aug 17, 2004
WhiteRabbit's Avatar
new panel built there from fiberglass or bodyfiller, or both.
angled up, it fits well, but chances are youll only be able to put a can of coke in the drinkholder.....
Old Aug 17, 2004
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
i've heard a lot of this thread and i cant find it. no matter how much i search.
fourkilos
Apr 20, 2004 07:42 PM
AzNmiKex215
Dec 28, 2002 09:36 AM
SilverBUll8
16
Nov 14, 2002 06:06 PM
Silla
Jun 26, 2002 03:20 PM
ZVotypka
Jun 11, 2002 08:22 PM
