some ECU wiring quetsions...
ok reading the post "2001-2003 civic ecu diagram" (http://www.7thgencivic.com/forums/sh...ressure+switch), i found a few things that seemed interesting (
)but have no idea what it means. i was wondering if you guys could clear it up for me.
heres the stuff i DONT understand/know:
Connector B (24 Pins)
7-red/blk-A/T Pressure control solenoid valve A
9-blu/blk-VTEC Oil pressure switch VTEC ONLY
16-blk/red-A/T Pressure control solenoid valve B
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins)– AUTO TRANSMISSION ONLY
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
Connector E (31 pins)
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
anyone got any ideas on what these things mean? thanks!
The VTEC switch is what engages VTEC.... its the signal to open the oil line to engage the secondary lifters... its looking for a PSI value that the computer puts with the other necessary parameters then triggers it.
The 2 on C are the solenoids that trigger gear changes... basically those are how the computer controls the AT.
The EVAP ones are for the charcoal canister. Its part of the emissions system, but I don't know really what it does.
What about Connector A: 6-wht-Primary O2 sensor
I can't find it! wht does mean white, correct? If so, I don't have a white wire coming into my connector A.
ah crap. I took all the connectors out and I was examining them all. I couldn't find a white wire. lol, maybe I'm just not look hard enough.
Thanks for the tip, though, Boilermaker1. I'll go try and finish what I started.
would tapping this line similar to how you tapped the VTEC solenoid be somewhat "good" to determine the VTEC activiation point?
sch2cm
Jul 21, 2015 09:58 PM
Roman Rembacz
Jul 16, 2015 12:30 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
