I have good news guys (injector related)....
Old Jul 2, 2004
opto_isolator's Avatar
Thumbs up I have good news guys (injector related)....
Well, everyone has been on my about the RSX injectors - well I just attempted to install them this morning....They FIT! See the following photos:
They are a direct replacement. The only modification that is necessary is the mounting studs on the intake manifold spacer plate.......
ID:	32148   Click image for larger version
ID:	32149   Click image for larger version
ID:	32150   Click image for larger version
Old Jul 2, 2004
dezod's Avatar
7thgen Power Maker
Originally Posted by opto_isolator
Well, everyone has been on my about the RSX injectors - well I just attempted to install them this morning....They FIT! See the follow photos:
THATS GREAT NEWS OPTO!
NICE JOB!
Old Jul 2, 2004
Hatorade's Avatar
SPLAT!!!
Hatorade is an unknown quantity at this point
so... u need to just extend the tabs on the fuel rail so it can bolt up?..
hmm.
question now is .... how does someone with a returnless control these.
Old Jul 2, 2004
Jodster's Avatar
Post Whore General
The RSX is a returnless setup too.
Old Jul 2, 2004
NICE JOB!
Heh - thanks for the help....Hope this helps out your turbo kit.....
Old Jul 2, 2004
Havok2k1's Avatar
Wicked Pissah Admin
NIce work Opto, have you fired the car up yet?
Old Jul 2, 2004
Well - I didn't actually start the car with them in yet - because I want to wait until my turbo is in so that I can limp it to the tuner (titan motorsports) and have them tune it for me....don't want to risk blowing anything for the moment. I put the old ones back in for now....just wanted to see if they would even fit or if there were going to be clearance issues.
Old Jul 2, 2004
dezod's Avatar
7thgen Power Maker
DID U USE THE RSX CLIP TO THE INJECTOR?
Old Jul 2, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
GOOD job opt
mine just came in but it's too hoot to mess witht he car today
mine is off a type S i beleive so i might have to get a different rail
Or is that the stock fuel rail...??
Old Jul 2, 2004
dezod's Avatar
7thgen Power Maker
Old Jul 2, 2004
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Test the emanage old injector/new injector feature now.
Old Jul 2, 2004
Hatorade's Avatar
SPLAT!!!
yea and whats ur point? unless ur using a rsx ecu, your post is pointless.
Old Jul 2, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Nice info man!!
Old Jul 2, 2004
Yes, it fits as well....Just like stock, only a larger injector
Old Jul 2, 2004
To clarify - I didn't have to splice anything - the RSX clips are exactly the same as the civic clips....
Old Jul 2, 2004
Green Civic's Avatar
Since you are using the rsx-s injectors, could that also mean that someone could use the aem fuel rail on the d17 motor?
Old Jul 2, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
So with this discovery, is it necessary to convert to a returnless fuel system? Or do you still need to make a return fuel system? Mine come in today w00000h000!
Old Jul 2, 2004
Your Parts Guy
Stock pump will still max out at a certain point. Even if you increase the voltage to increase output it will heat up and eventually fail.
Old Jul 2, 2004
Hwoody77's Avatar
Well how about with an upgraded fuel pump and no return fuel system, would it work that way?
Old Jul 2, 2004
Your Parts Guy
I would still bypass the in-tank FPR and install a boost referencing FPR like opto's Drag Aeromotive FPR under the hood. And at that point I would need to convert.
Old Jul 2, 2004
I don't believe it would. It MAY work - however there are two things to consider.
1. The injector spacing for the K20 may be different than the D17, since it is a larger motor.
2. The AEM rail I saw over at the clubrsx forums still had the pulsation dampener in the center (ala the RSX-S style - the RSX has it mounted on the END).
So - the stock RSX (non S) rail MAY work if:
- There are no clearance issues since it may be a larger rail
and
- If the injector spacing is identical to that of the D17.
Old Jul 2, 2004
civicskater's Avatar
Chicks dig my scent
awesome man i may just decide to dump the SF fuel kit if all this works out and convert to a return setup
Old Jul 2, 2004
gotti's Avatar
how much do these go for?
Old Jul 2, 2004
$95 a piece new. I bought a complete set off of some guy on clubrsx for $50...all flow tested excellent....
Old Jul 2, 2004
Your Parts Guy
The RSX is a gold mine of parts for us 7th gens and it keeps getting better.
Old Jul 2, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Talking
+1 to that!!!
Old Jul 2, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
sweet! good job opto! So if street level comes out with there return fuel set-up kit, than these injectors would hold up too boost?
Old Jul 2, 2004
jwcardy's Avatar
SRT-4 owner with 2MCHPSI
jwcardy is on a distinguished road
well since the cat is out of the bag!!!!!!!! Jeff and i will be putting out a return conversion kit...just give us a couple more weeks max...we are still trying to gather fuel rails...if anyone has extras, let us know...
Old Jul 3, 2004
Hatorade's Avatar
SPLAT!!!
so i guess i can order some 550 cc aftermarket rsx injectors :P
Old Jul 3, 2004
Yeah, they're called RC's.....RC makes a replacement for the RSX, but you still need to splice their clips to your wires for them to work - PLUS the clearance issue still exists....which is why I went this route to begin with, no modifications really necessary (except the mounting studs)....
