quick ? about relocating my battery
ok I have the relocation kit from summit racing for relocating my battery to the trunk. My question is for the positive cable, in the engine bay how should I connect the new positive cable with the ones that run to the fuse and altenator. I checked out this page http://www.personal.psu.edu/users/j/...51/battery.htm and I understand how that was done but can I bolt the cables down directly on that metal of the engine bay or do I need an extra spacer piece like shown in this pic
let me know thanks
let me know thanks
I persoanlly don't have this done, but if those cables are positive terminals, DO NOT, I REPEAT DO NOT touch those to the frame if the negative battery terminal is connected. You will have a very interesting light show not to mention some damage. Yes, you will have to find some way to keep those connections from EVER touching anything that runs to the ground (basically, the entire chassis). You can use some sort of phenolic material or rubber spacer. I install large scale generators and high voltage electrical panels and we have what we call isolation terminals that do exactly what you want to do. The are basically a rubber/phenolic material the has threaded studs embedded in it coming out of each end that are not connected. They also serve as vibration dampners. Although I haven't checked myself, you should be able to find them in Lowe's or someplace similar. We order them outta Grainger all the time...not to mention they shouldn't be too expensive. A couple o' bucks maybe...
On a side note/trivia...did you know you can weld with only a 12V car battery? Yes..in a pinch, it can be done...just lettin ya know how much juice can flow from it...
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
