All Upgrades to run more BOOST!!!
Old Jun 8, 2004
carbonrevo's Avatar
carbonrevo has a little shameless behaviour in the past
I was just wondering for those of you who have their D17 boosted and running anywhere between 7-14 psi, some are running at low 7s and some of you running at higher psi with stock internals.
Can any of you suggest what would be the best and most effective upgrades in order to run more boost and improve its efficiency at the same time?
Any opinions is welcomed. If upgrades are needed on SF's existing parts and need to be replaced also please post here as well.
ALSO PLEASE PROVIDE LINK or URL TO ORDER THOSE PARTS ALONG WITH YOUR POSTS. Thank you very much.
Old Jun 9, 2004
ImportRacer2123's Avatar
K20 Member
I don't know the links but i do know you need Bigger Injectors RSX ones might work. Pistons, Rods, sleeved or Block Guard (KMS has a blockguard)
or you can buy exospeeds built block for $2400 they say its bullet proof
Old Jun 9, 2004
civic01vtec's Avatar
#1 is sleeved block.
also....... pistons, rods, return fuel set-up with bigger injectors cuz SF's FMU isn't efficent enough to run higher boost. Also, you will need a piggyback.
Old Jun 9, 2004
carbonrevo's Avatar
which FMU should I purchase?
Old Jun 9, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
vortech 12:1
Old Jun 9, 2004
i wouldn't suggest a fmu for higher boost.......i suggest bigger injectors, return fuel set-up and a piggyback.
Old Jun 9, 2004
1320Racing's Avatar
1320Racing is an unknown quantity at this point
12:1 compression in a turbo motor
LOL
I have yet to see that in a 4cylinder
Internals
Internals
Internals
Old Jun 9, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Uh, he means a Vortech 12:1 FMU.....
You need a return system with full management system...
Old Jun 10, 2004
C2i0v0i1C's Avatar
SuperMODrizd
LOL
Internals
Internals
Internals
most sleeved blocks are bullet proof, they are tested between 40-55 on some. the people who are running double digit boost on their completely stock internals ARE STUPID!!!!!!! its only a matter of time, so dont get the idea that u should be like them. cover all ur basis before u get started so u dont have a headache later
Old Jun 10, 2004
carbonrevo's Avatar
Thanks for your advice, when you said cover your basis before getting started, what are the basis? Please list them out thanks again.
Old Jun 10, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
I think he meant bases.. like cover all your bases.. as in baseball
by that i'm sure he meant check out everything you can do, and know what you want to do.. (RESEARCH!!)
Old Jun 10, 2004
bic's Avatar
bic
bic is an unknown quantity at this point
rods, sleeves, pistons, engine management, how much boost do you want and how much money do you have to spend
Old Jun 10, 2004
carbonrevo's Avatar
I want to run around 9 psi for now. I do want to built my block after the turbo installation. It won't be done probraly couple of months after that, I'm just little frustrated with all these issues people are having after installed their turbos
Old Jun 10, 2004
K20 Member
How did you run your return fuel system? IF you would please help me out and PM me and maybe write me Up a DIY like what was needed and where to get it. etc... i would SOO Really appreciate it. Thanks Again man.
Old Jun 10, 2004
bic's Avatar
bic
You can pull 9 psi off with good fueling, ignition, ENGINE MANGEMENT AND TUNING unbuilt. This means no FMU or AFC hack. I dont know what is available for the D series as far as engine managment. I would also look into alcohol injection like the stafford kit has available. If I were you, I would run lower boost until you build, then turn up the boost since you are planning to build anyway.
Old Jun 11, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
what ratio is the SF Vortech FMU 8:1??
Old Jun 11, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Yes. Don't just upgrade to a 12:1 and expect more power... Learn how an FMU works first....
And CarbonRevo, you need to look through all the threads for your answers, this forum (esp FI) is FULL of information if you just look for it instead of asking for it... Research means looking and asking, not just asking... Especially when people spell it out in this post and you still ask for more details... The details are here bro, take time and look for it....
Edit: Also here are links to Opto's return setup thanks to tfnaaf...
http://www.7thgencivic.com/forums/sh...8&postcount=11
Edit 2: Ironically I searched more and found a thread labelled "DIY return fuel system"
http://www.7thgencivic.com/forums/sh...=return+system
Old Jun 11, 2004
actually, SF's is 10:1
Old Jun 11, 2004
C2i0v0i1C's Avatar
SuperMODrizd
cover the basics is what i meant in that post. by that i mean dont go around running 10+ boost on stock internals. STUPID!! bound to blow without reinforcements. pistons and rods will be the first things to go with this high of boost, then the sleeves. most people dont have the money to build and turbo at the same time, but its the smart way to go
Old Jun 11, 2004
C2i0v0i1C's Avatar
SuperMODrizd
as far as the DIY return system, and me posting one, that will never happen. bc 1. i didnt do it. 2. the guy who did it wont even tell me. hes proud that he got b series 440cc injectors to fit in my stock rail
Old Jun 11, 2004
Havok2k1's Avatar
Wicked Pissah Admin
So people are running 90psi of fuel at 9lbs?
Old Jun 11, 2004
well, nobody tested it with a fuel pressure gauge.........but theirs is a 10:1
Old Jun 13, 2004
bic's Avatar
bic
it would be more than that, you are only accounting for the pressure increase due to boost.
Old Jun 13, 2004
it would be like 130psi...
Old Jun 13, 2004
andyman97's Avatar
Turbo Guru
SF does increase 10:1 psi of fuel pressure per lb of boost. I had a fuel pressure gauge on my setup and everytime I hit 5 psi boost or more, my needle would bury at 100 psi fuel pressure. Couldn't tell you how much it was past that, my gauge didn't go higher than 100.
As far as buildup goes....
There are only a few things you need to do to make decent power. The real question is, how much power do you want? If you'd be happy at 250 hp, all you really need to do is tune your fuel and ignition. If you are tuned properly, you're internals can hold that much, it's been proven time and again on d16 blocks. A greddy emanage can do that for you. If you run, say, 10 psi, pull the correct amount of timing and spend a little bit of time on the dyno, you should be able to make over 220 whp on the dyno with an ex. Consider that to be roughly 240ish crank horsepower. With that, you are at your goal. It can be done with no bottom end work, you just have to tune your fuel curve to make power and make sure that your timing is where it needs to be so that you don't detonate and tear up the pistons and rods.
Old Jun 13, 2004
kezay's Avatar
kezay is an unknown quantity at this point
What do you feel is the highest compression we could run with boost (with the correct tuning)
Old Jun 13, 2004
andyman97's Avatar
Turbo Guru
I wouldn't recommend anymore than 10.5:1. Depends on how much you want to boost though. You could probably get away with more but you would need to use race gas. Personally, I think 9.5:1 is awesome for boost (which is what the d17a1 is).
Old Jun 16, 2004
motenkjr's Avatar
motenkjr is an unknown quantity at this point
where would we get a return fuel system from??
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
Reginator
Jun 17, 2015 07:54 PM
Supramk3
May 8, 2015 11:16 AM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
