Which All-Season Tires should I get for my stock 15".
Old Jun 6, 2004
silverem2's Avatar
Ok, So i have stock 15" rims(they look like the hatchback ones, im in canada so the ex rims are different). None the less they are aluminum rims. But my firestone 690 are pieces of ****. I need to get another All-season tire before winter but I dont know which ones and what I should be looking into. Mine right now are 185-65-15. I would like to get a little bit bigger, either a 195 or a 205, and would PREFER(not that big a deal if its not) either Pirelli or Yokohama or Toyo. Like I said, i want good, high performance ones. I notice that mine are shitty in the rain and any other time. Lead me in the right direction. I also am looking for some hi-rated( like v or so rated) tires that can handle higher speeds.
Thanks all for your help in advance
Old Jun 6, 2004
I really like my bridgestone turanza tires. Pretty good all around and not very noisy.
Old Jun 6, 2004
Zzyzx's Avatar
Autocross Junky
I'm running Continental ContiExtreamContats. Pretty good tire, good dry tracion and decent snow traction too..
Old Jun 7, 2004
Storm897's Avatar
Storm897 is an unknown quantity at this point
I agree, my neighbor has those and there great all season tires.
Continental ContiExtremeContact, ranked 3 out of 17 tires in Ultra High Performance All-Season Tires
Ultra High Performance All-Season Tire Rankings
Road test performed on the Continental Tires
Two other ones to consider:
BFGoodrich's Traction T/A V, ranked 3 out of 22 tires in High Performance All-Season Tires
Road test performed on the BFfgoodrich Tires
AND
Firestone Firehawk INDY 500 with UNI-T, ranked 1 out of 13 tires in Performance All-Season Tires
I currently have Kumho HP4 716 195/60/15 tires on my civic and there a lot better then the OEM ones. My next set will be in size 205/55/15, and will go on my stock oem steel wheels.
I think my next set will be either the Continentals or BFGoodrich.
Also, going from 185/65/15 to 205/55/15 will only throw your tachometer off by 2.25%. So when your tachometer says your going 100, your really going 97.75 mph.
Just in case you might ask:
1.) You wont need a new alignment for the new size tires.
2.) Different tires will only affect your tachometer.
3.) They will add more miles to your car by 2.4%. (negligable in my opinion)
Pricing for the tires above is:
$66 Firestone Firehawk Indy 500
$72 Continental ContiExtremeContact
$78 BFGoodrich Traction T/A V
Old Jun 7, 2004
zen_master's Avatar
hm, my bro just bought that tires for his 00SI....with 15" stock wheels...it's pretty expensive though....for 15" tires...
im considering Falken Ziex-512......
Old Jun 7, 2004
silverem2's Avatar
right now i am leanin towards the traction t/a v, just for the fact that i am willing to spend like 650 bucks on tires, that is one thing i wont cheap out on. And those fireshit i have one right now, have got to be the worst tire ever.
Old Jun 7, 2004
silverem2's Avatar
also, my next question, what size should i get? 205/60/15 195/60/15 205/55/15?? help me out
Old Jun 7, 2004
Storm897's Avatar
I currently have 195/60/15. Get 205/55/15. You'll feel improved braking due to a bigger footprint of your tire to the road, and your cornering ability will also increase. My braking impoved after I went from 185/65/15 stock tires to the 196/60/15 Kumho Hp4 tires. Once I go to 205/55/15 they will increase in braking and cornering ability even more. You might have a slight loss in miles per gallon though because you will have more rolling resistance due to the bigger footprint of your tire touching the road.
The reason I'm going 205/55/15 instead of 205/60/15 is because I want a lower profile tire to allow for less roll in the tire.
The reason I'm going 205/55/15 instead of 195/60/15 is because I want a bigger footprint on the road.
Hope this helped.
Old Jun 7, 2004
Storm897's Avatar
Another thing, those Firestone you have are the 690 model found here. There not the same Firestone model I showed above.
I wish tirerack would add the Falken 512s to there site so we would have a place to place ratings on them and compare to the other tires I posted above. Other websites have ratings but not enough. When only 5 people plaves reviews on a tire, a ratings can be severly driven off of 1 persons rakings.
Old Jun 7, 2004
Storm897's Avatar
If your willing to spend that type of money, maybe also look at the following tire.
Bridgestone Turanza LS-V
Heres a Comparison of the two
The bridgestone will last 40,000 miles while the BFGoodrich last 60,000 miles.
Overall, it looks like the Bridgestone are ranked higher in just about everything except treadwear life.
The Bridgestone are $164 more for all 4 ($41 more for each tire then the BFGoodrich).
Old Jun 7, 2004
zen_master's Avatar
that BFgoodrich is quite tempting...however, it's quite expensive...right?
moreover, they don't have the size of 215/45/R17...
Old Jun 7, 2004
Storm897's Avatar
$78 is not a bad price. Its about normal for a tire in that size.
This link shows prices for other BFGoodrich sizes.
Old Jun 7, 2004
zen_master's Avatar
hm.....no....$78 for the 15"
the 17" costs like $110....but, they don't have 215/45/R17...
Old Jun 7, 2004
Storm897's Avatar
I meant $78 for the 15.
Try this tire then for yourself:
$94 Continental ContiExtremeContact in size 215/45/17
Old Jun 7, 2004
zen_master's Avatar
wooooow.....
nice option! thank you!!
can you suggest more? for 215/45/R17..
my mind got stuck with Falken Ziex-512...i need some fresh air...he he he
Old Jun 7, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I'm considering Bridgestone Potenza RE950s 195/60/15 for my steelies, ~$90 each Installed at Costco. They're supposed to be softer than the Ziex 512s but with a stiffer sidewall, and a softer inner compound that is exposed as the tire wears. Seems like better dry/wet traction than Ziex 512s but less snow traction.
Old Jun 7, 2004
Storm897's Avatar
wooooow.....
Try this
Comparison of 3 Tires:
  1. Continental ContiExtremeContact
  2. Pirelli PZero Nero M&S
  3. Bridgestone Potenza RE950
I would suggest the Pirelli's for $116. There supposedly one of the best all season tire.
Old Jun 7, 2004
Sickboy's Avatar
^My work computer won't let me access that link, can you summarize it.
*Thanks Storm
Old Jun 7, 2004
Storm897's Avatar
Added so you can see it as a picture
Old Jun 7, 2004
zen_master's Avatar
oh damn..
now i got three choices, opinion plz guys!
3. Falken Ziex-512
all in size 215/45/R17
i need your opinion! hehe
Old Jun 7, 2004
UltimateStock's Avatar
UltimateStock is on a distinguished road
i payed over 120 each for my 16''s...=( kumo ecsta supras....for my supra! hah....great tires...felt soo nice on the street.
Old Jun 7, 2004
Storm897's Avatar
$95 245/45ZR17 Falken ZE-512 ZIEX
I heard Falken 512s are nice. Dont know how they compare to the pirellis though. The pirellis are the best tire on tirerack in the Ultra High Performance All-Season Tires Category
Old Jun 7, 2004
Storm897's Avatar
Get the BFGoodrich Traction T/A H instead.
The BFGoodrich rank higher in every category. Also, by the time there installed, its about the same price. It might be even cheaper.
Heres a comparison of the RE950s and the BFGoodrich tire:
RE950
Traction T/A H
Old Jun 7, 2004
Sickboy's Avatar
^Thanks, I'll definetly look into those. I just started looking into what I'm going to replace these Crapstones with, so I'm by no means decided. I'm looking for something with a stiffer sidewall, either 195/60 or 205/60, better dry and wet traction, decent treadwear (+30k), basically better than the Firestones in every category other than MPG.
My only complaint with Tirerack's reviews are that even though there are many, usually there are still retarded reviews by retarded people that skew the ratings (i.e. these summer tires suck in the snow so it's a crappy tire). So, if ratings are close between a few tires I find it neglible.
Thanks for the info and any other that you find.
Old Jun 7, 2004
silverem2's Avatar
thankyou for hijacking my thread ask about 17's in a new thread please
Old Jun 7, 2004
zen_master's Avatar
we're saving some space, here......LOL.
Jeffdp
Jun 18, 2015 06:18 PM
Pudnite
May 9, 2015 07:51 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
technosilver
Nov 14, 2001 10:58 AM
