Which All-Season Tires should I get for my stock 15".
Ok, So i have stock 15" rims(they look like the hatchback ones, im in canada so the ex rims are different). None the less they are aluminum rims. But my firestone 690 are pieces of ****. I need to get another All-season tire before winter but I dont know which ones and what I should be looking into. Mine right now are 185-65-15. I would like to get a little bit bigger, either a 195 or a 205, and would PREFER(not that big a deal if its not) either Pirelli or Yokohama or Toyo. Like I said, i want good, high performance ones. I notice that mine are shitty in the rain and any other time. Lead me in the right direction. I also am looking for some hi-rated( like v or so rated) tires that can handle higher speeds.
Thanks all for your help in advance
Autocross Junky
I'm running Continental ContiExtreamContats. Pretty good tire, good dry tracion and decent snow traction too..
Continental ContiExtremeContact, ranked 3 out of 17 tires in Ultra High Performance All-Season Tires
Ultra High Performance All-Season Tire Rankings
Road test performed on the Continental Tires
Two other ones to consider:
BFGoodrich's Traction T/A V, ranked 3 out of 22 tires in High Performance All-Season Tires
Road test performed on the BFfgoodrich Tires
AND
Firestone Firehawk INDY 500 with UNI-T, ranked 1 out of 13 tires in Performance All-Season Tires
I currently have Kumho HP4 716 195/60/15 tires on my civic and there a lot better then the OEM ones. My next set will be in size 205/55/15, and will go on my stock oem steel wheels.
I think my next set will be either the Continentals or BFGoodrich.
Also, going from 185/65/15 to 205/55/15 will only throw your tachometer off by 2.25%. So when your tachometer says your going 100, your really going 97.75 mph.
Just in case you might ask:
1.) You wont need a new alignment for the new size tires.
2.) Different tires will only affect your tachometer.
3.) They will add more miles to your car by 2.4%. (negligable in my opinion)
Pricing for the tires above is:
$66 Firestone Firehawk Indy 500
$72 Continental ContiExtremeContact
$78 BFGoodrich Traction T/A V
hm, my bro just bought that tires for his 00SI....with 15" stock wheels...it's pretty expensive though....for 15" tires...
im considering Falken Ziex-512......
right now i am leanin towards the traction t/a v, just for the fact that i am willing to spend like 650 bucks on tires, that is one thing i wont cheap out on. And those fireshit i have one right now, have got to be the worst tire ever.
Originally Posted by ati9700pro
also, my next question, what size should i get? 205/60/15 195/60/15 205/55/15?? help me out
The reason I'm going 205/55/15 instead of 205/60/15 is because I want a lower profile tire to allow for less roll in the tire.
The reason I'm going 205/55/15 instead of 195/60/15 is because I want a bigger footprint on the road.
Hope this helped.
I wish tirerack would add the Falken 512s to there site so we would have a place to place ratings on them and compare to the other tires I posted above. Other websites have ratings but not enough. When only 5 people plaves reviews on a tire, a ratings can be severly driven off of 1 persons rakings.
Bridgestone Turanza LS-V
Heres a Comparison of the two
The bridgestone will last 40,000 miles while the BFGoodrich last 60,000 miles.
Overall, it looks like the Bridgestone are ranked higher in just about everything except treadwear life.
The Bridgestone are $164 more for all 4 ($41 more for each tire then the BFGoodrich).
Originally Posted by zen_master
that BFgoodrich is quite tempting...however, it's quite expensive...right?
moreover, they don't have the size of 215/45/R17...
This link shows prices for other BFGoodrich sizes.
hm.....no....$78 for the 15"
the 17" costs like $110....but, they don't have 215/45/R17...
Try this tire then for yourself:
$94 Continental ContiExtremeContact in size 215/45/17
I'm considering Bridgestone Potenza RE950s 195/60/15 for my steelies, ~$90 each Installed at Costco. They're supposed to be softer than the Ziex 512s but with a stiffer sidewall, and a softer inner compound that is exposed as the tire wears. Seems like better dry/wet traction than Ziex 512s but less snow traction.
wooooow.....
nice option! thank you!!
can you suggest more? for 215/45/R17..
my mind got stuck with Falken Ziex-512...i need some fresh air...he he he
Comparison of 3 Tires:
- Continental ContiExtremeContact
- Pirelli PZero Nero M&S
- Bridgestone Potenza RE950
I would suggest the Pirelli's for $116. There supposedly one of the best all season tire.
Originally Posted by Sickboy
^My work computer won't let me access that link, can you summarize it.
oh damn..
now i got three choices, opinion plz guys!
1. Continental ContiExtremeContact
2. Pirelli PZero Nero M&S
3. Falken Ziex-512
all in size 215/45/R17
i need your opinion! hehe
3. Falken Ziex-512
i payed over 120 each for my 16''s...=( kumo ecsta supras....for my supra! hah....great tires...felt soo nice on the street.
$95 245/45ZR17 Falken ZE-512 ZIEX
I heard Falken 512s are nice. Dont know how they compare to the pirellis though. The pirellis are the best tire on tirerack in the Ultra High Performance All-Season Tires Category
The BFGoodrich rank higher in every category. Also, by the time there installed, its about the same price. It might be even cheaper.
Heres a comparison of the RE950s and the BFGoodrich tire:
RE950
Traction T/A H
^Thanks, I'll definetly look into those. I just started looking into what I'm going to replace these Crapstones with, so I'm by no means decided. I'm looking for something with a stiffer sidewall, either 195/60 or 205/60, better dry and wet traction, decent treadwear (+30k), basically better than the Firestones in every category other than MPG.
My only complaint with Tirerack's reviews are that even though there are many, usually there are still retarded reviews by retarded people that skew the ratings (i.e. these summer tires suck in the snow so it's a crappy tire). So, if ratings are close between a few tires I find it neglible.
Thanks for the info and any other that you find.
Pudnite
May 9, 2015 07:51 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
ask about 17's in a new thread please
