Weight of Wheels...
Old Jun 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Weight of Wheels...
What is considered a heavy rim and what is considered average?
Just curious since I just ordered new rims....
Old Jun 6, 2004
dru106's Avatar
ThE CoRRupToR
All i know that if u got 17's the average weight is between 15-20 lbs witout tires of course. Other sizes im not sure
Old Jun 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Hm...so what would an average weight be for 19's?
I just ordered 19s and they are 20.6 lb's...
Old Jun 6, 2004
dru106's Avatar
ThE CoRRupToR
WOW!! For 19's thats pretty good!! Got pics?
Old Jun 6, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Yeah I thought that was pretty good, considering how strong they are supposed to be! But I didnt know...
No pics or revieling of what rims till they come, I put them on, and take pics (which will of course happen the day, actually the SECOND, i get them ) Though, a couple people do know from IMs...
Anymore opinions on rims weights?
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
If your runing 19s then you shouldnt worry about the weight.. Because a 19 would need to weigh approximatly 12 LBS to have the same Inertia of the stock Steel 15, that weighs 20lbs....
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Im not worried by any means, I could care less about speed when driving a Civic, I was just curious.
Old Jun 7, 2004
zen_master's Avatar
waittttttt...
Z, you said what?
"a 19 would need to weigh approximatly 12 LBS to have the same Inertia of the stock Steel 15, that weighs 20lbs...."
can you explain that again?
If my new rims are 17 with 15-16lbs of weight....is that good or bad? (compared to the weight of mystock steelies right now)
Old Jun 7, 2004
HyaBoosta's Avatar
www.wheelsweight.net got tons of wheel weights.
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
your link didnt even work?
Old Jun 7, 2004
zen_master's Avatar
ain't working for me..
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
Its physics, Bascially the farther a weight is from the center of rotation the harder it is to get that weight to spin.... Meaning even if a wheel stays the same weight, if you make it bigger (15 to a 18 for example) that wheels inertia increases.
The basic formula for estimating this increase goes like this.. I=m(r^2)
I = Inertia
M= Mass (weight)
r = Radius
So a stock steel wheel (20 LBS @ 15") has an aproximat inertia of 4500 N. and a 20Lb 19 has an aproximat Inertia of 7220, to break that down in to more understandable numbers, 2k2EXCOUPE has basically added 12LBS to his total rotational weight. (Per Wheel) for a grand total of adding 48LBs added to the car in wheels alone.
Your 17s have an approximat Inertia of somewhere between 4335 and 4624, so you havent really changed the overall Inertia of the wheel Vs stock.
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
This doesnt realy affect speed, but it does affect acceleration and Braking.
Old Jun 7, 2004
HyaBoosta's Avatar
ooops left out the S www.wheelweights.net
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
I am fully aware of that. And by speed, I meant accelerationg also. As for braking, I have plans on doing a big brake upgrade in the very near future to take care of my braking situation (as I know the 19s will kill my braking ability with stock-sized rotors)
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
^^ big brake kits are only nessisary if you are overheating the brakes, They have Very little to do with actual Stoping distances... To decrease stoping distances you should be looking at 2 parts, 1: your tires. and 2: the pad compound you are using. Tires being the more important of the two.
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
A bigger rotor tho should give me better braking ability. Smaller rotors are **** will have a hard time stopping such a large wheel... Right?
I am not cheap with tires so its not like im putting shitty tires on them or anything, the new ones will be running Falken Azeni's, and im running Yoko ES100's right now.
I am running Powerslot slotted rotors and AEM pads currently for brakes and they really suck....Dont stop with ****, think its the pads?
I dunno I might be totally wrong about it all...
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
How do you mean "they dont stop with ****"? Is it a sponge like pedal feel? If it is, then you need to bleed the brakes. (If you cant remember the last time the brakes were Blead the do so now.) Otherwise I'd be looking to get a different pad. The AEM/nissin pad is a good allaround Street pad but it is not a high performance pad!!! For street use Look at Hawk HP+ or HPS (HP+ have a Higher Friction Level) Or Axxis Ultamates.
Contrary to popular belief, Big brake kits do Very little to actually Decrease braking distances. Their real Purpose is to deal with heat. They allow you to run the brakes Harder Longer before they overheat and Fade. So if you arn't currently overheating the brakes then they arent worth the $$ or added rotational mass.
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Haha alright. Ive never blead the brakes... i dont know how??
Plus they kinda squeek a little bit and make funny noises sometimes...
Plus, a big brake would look good i think cause i use my car for shows and with 19s, my rotors will look TINY.
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
If you want the look, GO for it. Just dont expect to stop any quicker.
about bleeding the brakes, Take it to one of those quikie brake places and tell them to do it. Just dont let them talk you in to any thing else...
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Nope, I dont take my car anywhere to have work done...
Can I do at my house? I have every tool possibly, plus my dad could help me, he probably knows how...
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Just talked to my dad- said he can help me with it.
I dont remember if me and my friend blead my brakes when we changed my rotors and pads and that might be my problem, OOOPS....So im going to do it this week hopefully.
Old Jun 7, 2004
zen_master's Avatar
so..
by using bigger wheel but lighter weight (compared to stock steelies), i do improve my car, right?
Old Jun 7, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Originally Posted by zen_master
so..
No, but it sure looks a hell of a lot better thats for sure
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
You'll get a little better turning responce out of your street tires, but other wise your braking and accleeration will remain pretty much unaffected. (as long as your 17s weigh about 15 LBS).
Old Jun 7, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
zzyzx...
according to your stuff.. urt just saying all the weight lies on the outer edge..
19" tires weigh less than 15" tires... so im just thinking...
a 19" wheel 20.6lbs+tire(15lbs)=35lbs
where a 15" light weight wheel +tire=35 lbs...
i mean i understand but all ur calculations are so precise but not accurate...
precise in the #'s but not accurate as in where the weight lies... if i broke the spokes off the wheels ^^ bought they prolly weight like 12lbs (each spoke prolly weight .8 and the center hub section 4lbs.... then the cast round section weighs 8-8.6 im just saying with all ur calculation u need to feel the wheels on ur car first hand to judge..
i am a very strong believer in your calculations and theories except for this one.. ive had light *** 15's and i've had light *** 19's (14.5lb 19's) the 19's weighed same as 15's 14.5lbs and when raced and put to extremes i liked the 19's better because of less body roll.. less give on the tires and more tire-ground ratio at all times...
JUST my opinion..
btw 2k2......ELI your rims are strong as **** monoblock rolled they are light...overall w/ tires lighter than my 14" stocks and really nice... you wont notice much of a difference than stocks w/ acceleration/braking/mileage.... u might lose .5-1 MPG but thats just because the friction rate of more tire-ground... the 215mm wide will create more friction than a 185 anyday... but im just saying their nice/****ing light for 19's (except for the forged aerospace aluminum 19's i offer at 14.5lbs.) but yeah u picked a good wheel.!!
riley
Old Jun 7, 2004
Zzyzx's Avatar
Autocross Junky
Typically 80% of a wheels weight lays in the rim its self, and Yes they calculations are just estimates. With out actually Disecting each section of the wheel its virtually impossible to calculate its rotational mass. There are simple formulas that allow you to calculate the Inertia of a wheel, but they are simplified, so they only give you an estimate on that wheels Inertia.
Your 19 Vs 15 feeling better when driven hard is an issue with tire side wall stiffness. with the proper tire that wouldnt be an issue. and example of this are my race tires, Falken Azenis RS in 205/50-15. These tires possibly have the Stiffest side wall of any Street tire out there. and when compaired against my 17s 215/45-17 the 15" handle and respond MUCH better.
General DIY
Sep 25, 2015 08:02 PM
Jrosa
Sep 14, 2015 08:24 PM
montanacivic
Sep 7, 2015 08:48 AM
MamaBear2015
Aug 27, 2015 09:29 PM
Mr.Beefy
Aug 12, 2015 04:39 PM
