engine noise on subs
Old May 30, 2004
Fletchman04's Avatar
Fletchman04 is on a distinguished road
Question engine noise on subs
im getting engine noise on my subs. i have my amp under the passenger seat and its grounded to where the seat belt bolts to the chassis. (behind the plastic piece on the bottom where the slider thingy is for the seat belt) how can i fix this problem? any other grounding sites that would fix this?
Old May 30, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Grounds need to be tight and on bare, I repeat BARE, metal ....
Old May 30, 2004
werm's Avatar
werm is an unknown quantity at this point
I use a star washer also, but it's not necessary. Also you keep it under your seat? Isn't that kinda risky? Specially in winter.
Old Jun 1, 2004
up4surf's Avatar
up4surf is an unknown quantity at this point
Do you have your power wire and RCA cables running together? That would give you noise.
Old Jun 1, 2004
diskreet's Avatar
I ran power on passenger side myself, and signal on drivers side. then i grounded on the small, like 2 inch tall, metal support bar running between the seats and trunk on the bottom. Just drill a hole and ground away! No noise for me with that set up.
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
ej8
Apr 13, 2015 06:36 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
