Recommended fuel set-up?
Old May 13, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey everyone, I just have a few questions on fuel set-ups for a turbo car.
I plan on piecing turbo a custom kit, using a T25/T28 Turbo which is a small turbo(Stock Eclipse turbo).
I plan on running about 8-10 PSI on the street.
Now my current set-up is a VAFCII.
What would be a good recommended set-up for my fuel system?
Convert to a return fuel set-up?
Injectors?
Someone help!
Old May 13, 2004
dragoon's Avatar
Convert to a return setup, get larger injectors (not absoutely necessary if you get an inline pump with a FMU), get a better computer (apexi AVC-R, greddy emanage, etc).
Look at all of those options and see which is best for you.
Old May 13, 2004
atl01's Avatar
this has been an atl01 production..
atl01 will become famous soon enough
maybe some of the stuff im trying to sell will help you, I have a......
Walbro 255lph pump 99-2000 si (will fit the 7thgen with modification at least i had it on mine)
Venom 310cc injectors
Nos fuel pressure regulator with B&M fuel pressure guage (you can only use this if you go with the return line set-up.)
I also have the fuel pump assembly that has been converted over to a return system, so really all you would have to do is modify your fuel rail and add a return line to it.
maybe some of this stuff will help you, pm me with any questions
Dani1993
Jul 24, 2015 09:02 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
