Which Spark Plug to Use With My NX Wet Kit???
Old May 13, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Question Which Spark Plug to Use With My NX Wet Kit???
sorry but I can't find a thread that talks about which spark plugs to use along with the NX wet nitrous oxide kit....
the denso iridium ik20??? or the IK22??? or is there a better one? the nickel???<<<I heard about it but not too sure about using them...
Is there a website where I can buy em cheap???
Thanks for the Help!!!
Old May 13, 2004
CivicHX01's Avatar
i'd say just get the ik20 because its not like your gonna be spraying all the time... i'd say get the colder ik22 if your running constant boost like turbo... i'm just using common sense, someone can correct me if i'm wrong..
Old May 13, 2004
Balut Eating Champ
will it affect my engine if I get the colder ik22 spark plug??? what's the Pros and Cons with the Ik20 and IK22???
--i'm still searching for spark plugs online...
Old May 13, 2004
CivicHX01's Avatar
http://www.densoiridium.com/heatranges.htm
IK20 is a "hot plug." Ideal for our 7thgens stock or with light mods.
PRO:
"This keeps the plug temperature higher overall which is ideal for stop-start city driving conditions. "
CON:
hotter engine and n2o spray isn't maximized
IK22 is a colder plug. Ideal for boost.
PRO:
"Cold plugs are typically used in racing conditions because of its ability to transfer heat out of the cylinder chamber quickly. Most turbo, supercharged and nitrous oxide applications use this type of plug because of the tremendous heat they generate. A colder plug can also minimize the risk of pre-ignition and detonation, "
CON:
"however if the plug is to cold there is risk of fouling during extended periods of idling and low-speed operation. "
Like i said... i'd say get the IK20 if you daily drive a lot... or get the IK22 if you plan on spraying and racing a lot..
Old May 13, 2004
Balut Eating Champ
^^^right on man! thanks! I'm getting my NX Kit a couple of days from now and my old IK20's needs to be changed anyway... so IK20 it is... Thanks!!!
Old May 13, 2004
CivicHX01's Avatar
walang anuman
Old May 13, 2004
Balut Eating Champ
waaaaaaaaaaahahahahahaha walanghiya naubusan pa ako ng englis!!!
Old May 13, 2004
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
uhhh ok
Old May 13, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
I have the nx wet kit too... and Im using the Ik22's... havent had any problems yet, but i only keep them in during the summer.
Old May 13, 2004
tfnaaf's Avatar
BLDNPSI Mod
http://www.7thgencivic.com/forums/sh...ht=spark+plugs
These are the plugs that NX recommended to me on the phone last year Part # R5671A-8. There may be better ones available im not usre but ive been using them for some time with no issues.
Old May 13, 2004
Havok2k1's Avatar
Wicked Pissah Admin
So I'm going to close this since we don't need two posts about the same thing.....
I know this was the first but the other one should be able to answer your questions, and if not, I can just unlock this for ya....
http://www.7thgencivic.com/forums/sh...hreadid=138299
mistermenphis22
Jul 13, 2015 04:43 PM
General 7th Gen
Jul 9, 2015 10:17 PM
stvpagn
Jul 9, 2015 09:59 PM
1khilari
Jul 9, 2015 08:12 PM
MamaBear2015
Jul 3, 2015 11:26 PM
