My friend has a problem w/ starting his car
Old Apr 28, 2004
MangoEX's Avatar
Just Be
MangoEX should not be trusted
It's a '91 Toyota Cressida w/ the 7M-GE motor w/ turbo/etc pushing around 500+ RWHP.. anyway it's been a project car, sitting in his garage, and we re-wired the ECU completely w/ all clean connections, everything done up according to the manual, and it has power to the lights, fuel pump charges in the ACC mode, but starter won't crank. We will be looking at it again tommorow but My guess is that the starter motor isn't getting a good ground since it isn't even clicking/cranking the motor.. good guess? Thanks..
Old Apr 29, 2004
MangoEX's Avatar
Just Be
looked at it, still wont start... weird.. if the ecu is fried, will the starter not crank at all?
Old Apr 29, 2004
skipbarber's Avatar
check ignition harness, make sure its outputing 12v when you crank. the starter should be bolted to the engine..therefore the whole starter should be A ground. check starter relay under the hood. I dont see why rewiring the ECM would prevent starting...i could understand the ignition system not working, but the engine should at least turn over.
Old Apr 30, 2004
invasian's Avatar
invasian is an unknown quantity at this point
ummm...check the starter?
Old Apr 30, 2004
bickford05's Avatar
bickford05 is an unknown quantity at this point
yeah make sure it works before you tear everything else apart
SidCivic
Nov 24, 2015 08:36 AM
Kyrian
Jun 26, 2015 11:48 AM
mapdog
Jun 22, 2015 05:36 AM
HiImBrandon
Jun 1, 2015 07:34 AM
beveragemp
May 25, 2015 07:11 PM
