wheel spacer
Old Mar 28, 2004
macrossranma's Avatar
macrossranma is an unknown quantity at this point
wheel spacer
just put back summer rims on yesterday, but the tires are hitting the inner fender, will wheel spacer help?and how thick can i go?
thanks!
Old Mar 29, 2004
robbclark1's Avatar
Retired suspension supermod.
why would a wheel spacer help? it will just push the tire FURTHER into the wheel wheel and fender. You can a) roll your fenders b) change your drop if you have coils or c) pull the camber in negative.
Old Mar 29, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
I think when he said "inner fender" he might of meant the inner part of the wheel well closest to the engine.
Old Mar 29, 2004
tfnaaf's Avatar
BLDNPSI Mod
I strongly discourage the use of wheel spacers. I've seen to many cause more problems than they are worth
Old Mar 29, 2004
Zzyzx's Avatar
Autocross Junky
If you use them its a good idea to get longer wheel studs, and its a good safty thing if you ever go racing.
they would probably do the trick, but I'd be weary about changing the offset too much as you may start hitting the fender.
Old Mar 30, 2004
yes, sorry, i meant the inner part of wheel well close to engine, hope 3mm spacer wont be too much and i dont need to get longer studs, just the summer rims and tires have problems since im using 215/45/17 7.5" with 45offset, the race wheel shouldnt have any problem cuz its 205/50/15 6.5" 40offset
Old Mar 30, 2004
Exbauer's Avatar
Exbauer is an unknown quantity at this point
really, how low is your car? i have 215/45/17 w/ 45 offset with neuspeed sport springs with no rubbing. i might have a little when turning really hard, but that is rarely.
Old Mar 30, 2004
my car is about 2" lowered, plus i have a very visible toe in, will bring it to alignment soon but i know it wont totally fix the problem
Old Mar 30, 2004
bobbyd's Avatar
This is a great thread cause I am going to lower my ride this year and I have Quantum Tek wheels which are 7.5" with a 45mm offset and I am riding on 215/45/17's as well.
Tedverseti
Apr 23, 2020 01:45 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
twd000
Oct 4, 2015 12:52 PM
siliconvalley
Sep 15, 2015 09:48 PM
rainman15
Sep 6, 2015 11:10 AM
