wheel spacer
wheel spacer
just put back summer rims on yesterday, but the tires are hitting the inner fender, will wheel spacer help?and how thick can i go?
thanks!
thanks!
why would a wheel spacer help? it will just push the tire FURTHER into the wheel wheel and fender. You can a) roll your fenders b) change your drop if you have coils or c) pull the camber in negative.
Autocross Junky
If you use them its a good idea to get longer wheel studs, and its a good safty thing if you ever go racing.
they would probably do the trick, but I'd be weary about changing the offset too much as you may start hitting the fender.
yes, sorry, i meant the inner part of wheel well close to engine, hope 3mm spacer wont be too much and i dont need to get longer studs, just the summer rims and tires have problems since im using 215/45/17 7.5" with 45offset, the race wheel shouldnt have any problem cuz its 205/50/15 6.5" 40offset
This is a great thread cause I am going to lower my ride this year and I have Quantum Tek wheels which are 7.5" with a 45mm offset and I am riding on 215/45/17's as well.
nirvanaguy
25
Oct 26, 2017 07:26 PM
