coilovers + camber kit
i want to drop my car about 1.5". should i go with coilovers or lowering springs? i heard coilovers don't give a good ride. also, will i need a camber kit?
ehh, im not gonna flame anyone but u should check out this link...
http://www.7thgencivic.com/modules.p...Suspension+FAQ
if u have any specific questions, just ask.
i have skunk2 coilovers and rear spc camber kit. i love the ride.. but my front is too low (2" ish) and im hittin bumps everyday just from daily driving..
getting coilovers is good if you want to adjust the height usually between 1-4 inches. If you want just a standard drop, then getting lowering springs is what you want. You will want to get a camber kit unless you want to buy tires often. The camber kit will get your alignment back within factory specs so your tires will wear slower.
But yeah, SEARCH and learn...
Get some lowering springs if you just want a drop...if you want it to be adjustable, go with coilovers. Either way, keep in mind the ride will be STIFFER...so you might want to go with some Koni's if you get just the springs...they help a TON !!!
Hutch1051
Sep 29, 2015 09:20 AM
beanhead
Sep 24, 2015 12:04 PM
