coilovers + camber kit
Old Mar 28, 2004
veloz's Avatar
veloz is an unknown quantity at this point
i want to drop my car about 1.5". should i go with coilovers or lowering springs? i heard coilovers don't give a good ride. also, will i need a camber kit?
Old Mar 28, 2004
jttegx's Avatar
OMNES AD UNUM
ehh, im not gonna flame anyone but u should check out this link...
http://www.7thgencivic.com/modules.p...Suspension+FAQ
if u have any specific questions, just ask.
i have skunk2 coilovers and rear spc camber kit. i love the ride.. but my front is too low (2" ish) and im hittin bumps everyday just from daily driving..
Old Mar 28, 2004
streetglower's Avatar
getting coilovers is good if you want to adjust the height usually between 1-4 inches. If you want just a standard drop, then getting lowering springs is what you want. You will want to get a camber kit unless you want to buy tires often. The camber kit will get your alignment back within factory specs so your tires will wear slower.
Old Mar 29, 2004
FattyMcJ's Avatar
Addicted to the Twisties!
As long as you go to a GOOD alignment shop. The guy I took mine to DIDN'T EVEN KNOW YOU COULD CHANG THE REAR CAMBER...so I had him do it TWICE, after I showed him how !!! lol
But yeah, SEARCH and learn...
Get some lowering springs if you just want a drop...if you want it to be adjustable, go with coilovers. Either way, keep in mind the ride will be STIFFER...so you might want to go with some Koni's if you get just the springs...they help a TON !!!
Old Mar 29, 2004
That happened to me, I went to get a alignment awhile ago and the guy didnt know how to adjust the rear toe. What a bunch of idiots.
Old Mar 30, 2004
veloz's Avatar
thanks for the help!
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
