Steering wheel shaking
Old Mar 9, 2004
o0aznbboy0o's Avatar
o0aznbboy0o is an unknown quantity at this point
My steering wheel shakes back and forth when i brake from driving on the freeway going 70-90ish. at low speeds it doesnt shake when i brake. at first i thought it might be low air in my tires, but i pumped them and its still a problem. is this something i should goto the dealer for or is there something i can do about it. thanks in advance.
Old Mar 9, 2004
streetglower's Avatar
sounds like you having a brake problem. go and have your brakes checked, because I have always heard that if you stop and your steering wheel shakes, something is wrong with the brakes.
Old Mar 10, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
Sounds like you have warped brake rotors. Does your brake pedal vibrate too?
Most dealers will resurface your rotors for free, if it's still under warranty.
Old Mar 10, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
its not always the brakes or the rotors, sometime its just the rims is not balance, but if its not that then it will be ur rotors.
Old Mar 10, 2004
Ronin's Avatar
He said it only shakes when he brakes, which is why I didn't think that the problem was unbalanced wheels.
If the problem was unbalanced wheels, his steering wheel would be shaking at highway speeds regardless of whether or not he was braking.
Old Mar 11, 2004
egot2da4th's Avatar
egot2da4th is an unknown quantity at this point
yeah i have the same problem but it shakes when i'm on the fwy too....
do u have rims? cuz i noticed that after i got rims
i'd thought since the tires are thinner than stock, we feel the bumps more ya kno
Old Mar 11, 2004
Kloverz's Avatar
Man im having the same problem to when i brake it shakes from going 60 to whatever so what i did is change my rim, it was the rims it was not balance,
Old Mar 11, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
i had that problem on my 02 civic. The brake pads were wron out and the rotors were worped.
Old Mar 14, 2004
bart4man's Avatar
bart4man is an unknown quantity at this point
If it is happening at highway speeds and not when braking, it is most likely your tires are out of balance. Simple fix, get them balanced. It is not your brakes.
If it is pulsating under braking, most likely your rotors are warped. Have them turned out or replace them.
Old Mar 15, 2004
WhiteCastle's Avatar
http://www.7thgencivic.com/forums/fo...5&pagenumber=5
Old Mar 16, 2004
theman's Avatar
theman is an unknown quantity at this point
Try an alignment , it work on mine.
Old Mar 20, 2004
sw388integra's Avatar
might be an alignment prob....^^^like he said
Old Mar 20, 2004
dubz01si's Avatar
dubz01si is an unknown quantity at this point
sum it down to this your rotor are warped if you stop hard constintly this happens time 4 new rotors pal
Tedverseti
Apr 23, 2020 01:45 PM
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
qlitten
Jul 21, 2015 03:12 PM
