225/40zr18 Front And 215/35zr18
Balut Eating Champ
I'm getting new tires for my 2k1Civic, dropped 1.75 with camber kits, though I was thinking about putting 225/40ZR18 to the FRONT
for more meat and to cover the 2" gap in between, and the REAR's just perfect with 35's. My question is... would it affect my suspension and or handling???
, did anybody tried this already? how did it perform? I really need some feedbacks, I'm buying tires in couple of days... Thanks! Happy Holidays!
P.S.
Nankang tires sucks a$$!!!
P.S.
Autocross Junky
Unless you are pushing the car to its absolute limit you will probably not have any handling problems.... if you are, the car may want to oversteer at its limits.
Balut Eating Champ
I am NOT talkin' about drifting or drag racing, I'm just lookin at cruisin
... daily driving i.e. 70-110 mph on the freeways
, and street cornering 90-180degrees not to excess 40 mph sorts of stuff
... 225/40 FRONT AND 215/35 REAR will oversteer and or understeer pretty quick
? I lowered it with Goldline Springs 1.75 dropped and had R1Racing RearLower and RearUpper Struts... What if I put the same width but a little thicker on FRONT? i.e. 215/40 FRONT AND 215/35 ON REAR?
Thanks for the info guys! much appreciated!
Thanks for the info guys! much appreciated! Last edited by pnoyster2k1cvic; Dec 26, 2003 at 11:49 PM.
Well its not uncommon to see a width down in the rear on some FWD racecars (its a somewhat common ITR/CTR thing)... it neutralizes the car a bit because it makes the car more rear-end happy, but on the street, I dont think so.
It'll throw your speedo off, look odd, and if you're daily driving, you'll never be able to rotate them. if you've got 2" in the front and no gap in the back, your suspension has some issues, or you need some stiffer springs to handle the weight of your subs. Find a way to lose some of the weight in the trunk or call someone about increasing the spring rate in the rear.
The Standard One
ya just keep it the same... its would look way weird. even 215-40 vs 215-35 is a big difference. just because it closes the gap doesnt mean it'll look any better. the front will be alot higher than the rear and drop the rear even more because of the leverage..
i suggest you call goldline and get the springs replaced with the correct ones..
Balut Eating Champ
My goldline spring sags, I only used it for about less than a year... can I get this thing exchanged?... I was thinkin bout screw the damn thing... the suspension on 2k1Civic is hell anyway... so I'm thinkin bout replacing the whole thing with Tein coilovers Street Type...
Balut Eating Champ
Yeah that, and when I got it installed, at first it wasn't hitting the side fender, but now, everytime I get into a dip, it hits the fender, so now either I get me a coilovers considering the 2k1Civics suspension's sux, or get the whole suspension kit, or get my wide body conversion...
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Jul 14, 2015 03:39 PM
muttleytm
Jul 11, 2015 06:00 PM
