EP3 Civic Type R Shocks
Old Dec 23, 2003
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Hi all, I was thinking of swapping my 2001 civic sedan shocks for the EP3 Civic Type R shocks. Anyone here has done that ? I learnt from another member here that the EP3 uses a 16mm upper bolt to hold the shock in place with the knuckle arm as compared to our civics which uses a 14mm bolt. I was thinking if the bolt was 16mm then it will not fit the knuckle arm on our cars already. Anyone knows ? Another thing is that at the koni website, it is stated that the konis for the EP3 Civic type R are of a different part number from our EM civics. It is not gas but hydraulic. Isn't gas shock absorbers suppose to provide better damping ? Why does koni come up with an insert which is hydraulic for a much better performing car, EP3 Civic Type R ? Anyone here using the EP3 Civic Type R koni inserts on their EM rides ? If they are of the same diameter and perform better, it would be better to get them rather than the EM replacement konis. By the way, they are damping adjustable as well.
Old Dec 23, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
duno using EP3R Tein type flex coilovers though
Old Dec 24, 2003
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
did you have to modify anything to get the type flex to fit on the EM??? i am looking at doin this also.
Old Dec 24, 2003
Zzyzx's Avatar
Autocross Junky
just curious, but what makes you think that CTR shocks will be better then the Konis?
Old Dec 25, 2003
GaryC17's Avatar
I would thing the CTR shocks are better as the car was built for the track. The shocks should be able to take hard trashing. Right now I just need to know if they can fit the EM. Since the cost of the CTR shocks are the same cost as the Konis, it would be good to get them as they are direct replacement. When these fail, we can still get replacement inserts from konis.
Old Dec 25, 2003
there was only modification needed in the hood webbing it needed to have two holes cut in it
Old Dec 26, 2003
GaryC17's Avatar
That is if you are using the Tein flex coilovers. I am referring to the OEM shocks for the EP3 CTR.
Old Dec 26, 2003
they will fit without anything needed i was replying to crazycakes guys post i would just get a full set of coilovers if i was u though not worth ruining a set of shocks that ur gonna pay for when they arent made to preform with lowering and what not
Old Dec 26, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
well if its going on a sedan.. be prepared for some rear end sagging...
the rear shocks arent made for supporting that extra weight...
Old Jan 1, 2004
BlackSI's Avatar
BlackSI is an unknown quantity at this point
i'd be curious to see if the suspension on the 2004 EP3 would fit our cars. looks like honda upgraded it some
GaryFishell
Apr 24, 2015 06:49 PM
Rardon6thgenCiv
Apr 15, 2015 07:37 PM
Thees1
Apr 14, 2015 08:23 AM
eissal
Nov 8, 2001 02:37 PM
