lopsided
Old Dec 30, 2003
Jonauto's Avatar
Jonauto is an unknown quantity at this point
lopsided
is it normal for one side to be higher than the other when u just put the springs on ( back right) and will this fix itself?
BTW they are goldlines
Old Dec 30, 2003
flotsamm's Avatar
The left side is heavier, so it'll look like its leaning slightly to the left. There's a TSB that mentions this is normal. I noticed this the first day I had my Civic in my garage... kinda freaked me out until I found out its okay. It about 1/4" difference.
Old Jan 1, 2004
Jonauto's Avatar
i measured the difference between the two sides and it was more like 9/16. it is quite noticeable.... i have a speaker box in the trunk that probably weighs 100 pounds but is completely centered.
Old Jan 1, 2004
slicksivik's Avatar
its the stuff in ur trunk that is making it lower. if u have a coupe u shoulda got sedan goldline springs because there stiffer and they wont sag as much with all the weight, or at least look less uneven. this was covered a long time ago when they had a goldlines gb if u search.
Old Jan 1, 2004
slicksivik's Avatar
also, isn't the exhaust on the right side too, so that might weigh it down that little much more, i dunno.
elstevodiablo
Aug 16, 2010 10:35 PM
Tragedy
Jul 29, 2008 06:53 AM
reddawnman
Jan 4, 2008 07:37 AM
