Flywheel with turbo
Old Nov 19, 2003
CarbonFly's Avatar
Question Flywheel with turbo
Hey Catalyst and SFPower, I have the ACT Prolite 8.4lbs flywheel. Are there any possible problems that can occur when using a lightened flywheel with a turbo?
I have just been notified that Fidanza has released a 6.5lbs flywheel for our car. I would like to change to Fidanza to get as light as possible.
Basically, which flywheel do you think is the best for a turbo setup and why?
A. Stock
B. ACT - 8.4 pounds
C. Fidanza - 6.5 pounds
Thanks, btw......I am also getting the ACT HC5-XTSS clutch.
Thanks for your help.
Old Nov 19, 2003
RiceBuRNeR's Avatar
Turbo Member
I have the same flywheel too, trust me you dont want to go any lighter. Its allready a pain during normal shifting. Although having a lighter flywheel does make the engine rev easier, thus spool the turbo faster there is such a thing as too light when you have a street car.
Old Nov 19, 2003
RiceBuRNeR's Avatar
Turbo Member
BTW: stock is like 13.4 lbls
Old Nov 20, 2003
CarbonFly's Avatar
Does the car idle ok? Does it have a higher or lower idle rpm?
Old Nov 20, 2003
chrisgushue's Avatar
Bring Hockey Back!
chrisgushue is an unknown quantity at this point
how hard is it driving in rus hour? pain in the *** during stop and go traffic?
Old Nov 20, 2003
RiceBuRNeR's Avatar
Turbo Member
It idles fine unless you turn the AC on. Its not too bad in trafic accept for the fact that it looses revs very quick, so you always have to "speed shift".
A light flywheel make the power band narrower so If you go too light everytime you shift youl drop out of the power curve.
Old Dec 4, 2003
Elite's Avatar
Elite is an unknown quantity at this point
its gonna be retarded getting a 6.5lbs flywheel because you are going to be shifting so quick it aint worth it, i stuck to the 11 lbs act one the flywheel will go and probably ruin your car.
Old Dec 4, 2003
CarbonFly's Avatar
How do you figure?
Old Dec 4, 2003
CarbonFly's Avatar
Why is that? Do you stall out or something? What exactly happens?
Old Dec 5, 2003
Quiksilver09's Avatar
Quiksilver09 is an unknown quantity at this point
I could see too light of a flywheel causing at least two possible problems. 1) When you shift very quickly you're putting extra stress on your transmission because of the sudden jolty movements you make with the shifter, or 2) the clutch will go through serious wear and tear if you're not rev matching while shifting every time in normal everyday traffic.
Old Dec 6, 2003
futurersxswap's Avatar
Passin' You On 19's.....!
futurersxswap is an unknown quantity at this point
i have a 11lb act one.. didnt wanna go lower.. but then again i have another 6 lbs of the crank on the other side of things with my crank pulley... my motor revs like WHOA.. not to mention i never see anything below 7psi if im driving hard... then it goes straight from 7 to 9.. and sticks there nice and perfect.. i LOVE my car!
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
beanhead
Sep 24, 2015 12:04 PM
naokigoffi
Aug 30, 2015 06:19 PM
justcruzin125
Aug 11, 2015 09:09 PM
