clunkin noise with sportline
Old Nov 19, 2003
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
ok here is the story.....eibach sportline came with a rubber isolator around the coil (rubber hose)....i removed it, cuz i had no idea what they were for
now that they are in my car, everytime i go over bumps or turn my steering wheel they make clunking noises. its pissing me off
so i looked down at my springs....the first 3 coils are touching each other.
so my question is, is that the problem cuz they are touching? should buy rubber hose and slide it in between?
thx yall
Old Nov 19, 2003
Lek's Avatar
Lek
Lek is an unknown quantity at this point
Yep, give it a try. It won't hurt. Clunks over bumps pi....ed me off, too for over a year until I did this.
Old Nov 19, 2003
HYPR DRV's Avatar
Since 1977
HYPR DRV will become famous soon enough
WOW, you are like the first person I've seen on here who has actually figured out their own problem!!!! CONGRATULATIONS!!! No offense to all those other peeps; I used to be one.
Put the isolators back on and wrap it around the coils that are touching. Bye bye noises!!
Old Nov 19, 2003
PunkingCivic's Avatar
I need TP for my bunghole
Check the following
1. Make sure that all the nuts at the top of the front struts is tight.
The nut that holds the the spring and strut together was loose and made a noise like that.
2. Make sure the springs are properly seated.
3. Put the hose between the dead coils (coils that touch each other.)
This will eliminate some noise.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
