Post Pics
Post Pics
I need pics if you guys find the time..
I need to see a pic of the fuel rail with the fitting welded on the end for the return fuel system and any other pics of this setup if you have time...
I have all of the parts in and are ready to be installed but I need to know where to get this welded....
Thanks
Brandon
Thanks
Brandon
YOU ROCK BRO
couple of questions:
Did you have to put an extra hole in the top of the gas tank cover for the return line?
Do you need any extra fuel line "in" the tank?
What size is the welded fitting and where did you get it?
What size are the npt fittings on the lines?
Brandon
Brandon
Originally posted by chesireCAT
YOU ROCK BRO
Brandon
YOU ROCK BRO
Brandon
That fitting dumps directly into the tank. I replaced all the fuel lines in the tank though. You HAVE to if you are using a bigger pump or higher pressure. that whole setup in the tank isn't made to withstand much. Plus you have to get rid of a lot of parts to get a 92-00 Civic 255lph pump in. Blah blah blah. etc etc.
I dunno. Parts list is at home (CT).
No NPT. -AN!!!! I'm going aerospace technology biotch!
Originally posted by CivicRacer5
what parts are needed to run the return line? Is it difficult? How much would it cost me to have done at a shop?
cost per hour*hours worked=ur bill
Wild Cranker
427
Jan 28, 2016 06:49 PM
