Post Pics
Old Nov 11, 2003
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Post Pics
I need pics if you guys find the time..
I need to see a pic of the fuel rail with the fitting welded on the end for the return fuel system and any other pics of this setup if you have time...
I have all of the parts in and are ready to be installed but I need to know where to get this welded....
Thanks
Brandon
Old Nov 11, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Give me a couple minutes...
EDIT: The end of the fuel rail is the only thing that needs to be welded. There shouldn't be any other welding involved
Old Nov 11, 2003
Boosted2k2's Avatar
Fuel Rail coming soon...
RETURN LINE TO TANK:
Old Nov 11, 2003
Boosted2k2's Avatar
RETURN LINE TO RAIL:
Old Nov 11, 2003
chesireCAT's Avatar
YOU ROCK BRO
couple of questions:
Did you have to put an extra hole in the top of the gas tank cover for the return line?
Do you need any extra fuel line "in" the tank?
What size is the welded fitting and where did you get it?
What size are the npt fittings on the lines?
Brandon
Old Nov 11, 2003
SpdRcrChk's Avatar
BOOST JUNKY
SpdRcrChk is an unknown quantity at this point
Boosted.....u rock.
Old Nov 12, 2003
Boosted2k2's Avatar
Originally posted by chesireCAT
YOU ROCK BRO
Brandon
Yes... extra hole in the top, fuel resistant grommet... it's in there nice and tight. (Fitting goes through... nut on the other side screws it together tight)
That fitting dumps directly into the tank. I replaced all the fuel lines in the tank though. You HAVE to if you are using a bigger pump or higher pressure. that whole setup in the tank isn't made to withstand much. Plus you have to get rid of a lot of parts to get a 92-00 Civic 255lph pump in. Blah blah blah. etc etc.
I dunno. Parts list is at home (CT).
No NPT. -AN!!!! I'm going aerospace technology biotch!
Old Nov 12, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
what parts are needed to run the return line? Is it difficult? How much would it cost me to have done at a shop?
Old Nov 12, 2003
opto_isolator's Avatar
Ok - for the benefit of CC (as well as the rest of us) - please post a parts list if you can. I for one am planning on doing this well.....Thanks!
Old Nov 12, 2003
C2i0v0i1C's Avatar
SuperMODrizd
depends on the shop, if they charge by the hour for custom labor then well
cost per hour*hours worked=ur bill
Wild Cranker
427
Jan 28, 2016 06:49 PM
Hobby2K
Bolt-on Engine Performance
Nov 14, 2001 01:56 PM
